The problems with GDI
I think the ad on T.V. for VALVOLINE Restore and Protect claims pistons / rings and no mention of valves . PENNZOIL Ultra Platinum ( S.P.,GF-6A ) should clean just as well as the R&S . P.U.P. also has G.M Dexos1 Certification for 0w-20 , 5w-20 and 5w30 at their site under Industry Specifications and O.E.M. Specifications ( v BELOW v ) .
https://www.pennzoil.com/en_us/prod...0L3Bhci9pZnJhbWVkYXBwLnN0YXRpYy9pbmRleC5odG1s
Here are the VISCOSITY Details : Technical Data Sheets ( 0w-20 , 0w-40 , 5w-20 , 5w30 , 10w-30 )
PUP will run clean but can't clean piston deposits like R&P.
R&S and P.U.P. 0w-20 for comparison . P.U.P. 0w-20 V.O.A. from 4/21/24 . These are from YouTube videos . Both look to benefit G.D.I. and D.I..
P.U.P 0w-20
Wow, going by the VOA of the Restore and Protect, the 5W-20 seems more robust then the 0W-20. Magnesium, Zinc and Moly specifically.
Still not sure what's in it to allow the restore part to work. I believe the protect part.
  • Like
Reactions: 4WD
Put some catch cans in line between the PCVs and the manifold.
I did on mine, hooked up both side to it. Filled it up in about 10000. A mishimoto unit. Gm says that they "fixed this issue with the L8T, which is another lie.
nterested to know the mode of some on this forum on this topic. Some find there to be no issues with these designs, while other hate them. Do some here have some real world usage data or experiences with DI? Can you substantiate some of these issues, or write them off as just a nothing burger? Are there any mechanics who in the past 10 years or so observed issues that did not exist before the industry's change to this new "better" system?
Mazda Skyactiv has an air/oil separator. (before the PCV valve) Still if there is a market you can be sold a can. (money before brains)
Who here has serviced their air-oil separator? If so what was its condition? I have a 2014 Mazda3 coming up on 60k miles. I need to change the coolant soon and should at least check this too while I'm down there. I'll add that in the service manual diagram the air/oil separator looks too small to be effective.
View attachment 249138View attachment 249139View attachment 249140
On the new GM 6.6 L8T, hte issue with gases reentering the intake was suppose to be solved with some engineering under the valve covers. This was one of the main selling points to me, when I bought one in 2020. GM, full well knowing the issues of GDI and valve coking............
This was not the case. Whatever they did to stop the issue of evaporation and recirculation back into the intake did not and does not work.
I installed a catch can, on one side of the engine, driver side is i remember correctly, with a top of the line Mishimoto catch can, inline of the PCV system. After 3000 or so miles, it was nearly full, as witness by the sight tube on the side.
I think more should be incorporating this into the design as I think it would help with the coking issue, and the subsequent and very costly repair of a system that should not even be an issue on a modern vehicle.
You separator, should it be working is no doubt full, slap full. It should be a part of normal maintanance, just like an oil change.
https://www.enginebuildermag.com/20...e-direct-injection-issues-facts-fictions-gdi/
Interested to know the mode of some on this forum on this topic. Some find there to be no issues with these designs, while other hate them. Do some here have some real world usage data or experiences with DI? Can you substantiate some of these issues, or write them off as just a nothing burger? Are there any mechanics who in the past 10 years or so observed issues that did not exist before the industry's change to this new "better" system?
I can only speak for my own circumstance
The problems are lazy, broke vehicle owners who won't do the necessary maintenance and won't take unpopular steps to reduce the carbon / soot buildup.
Mid/premium fuel, 12k intake spray cleanings, shortened OCIs and Dexos 1 Gen 3 oils are just 4 of numerous, unpopular ways to help keep the engines cleaner.
Do a Google Search on this subject and find more ways. But if you just want to look at your GDI / TGDI outside in the backyard and continue to sit on your hands, then expect conditions to worsen over time.
I agree with your best practice GDI engine maintenance suggestions TripleSeven . Conversely , say the best vehicle owner follows their owners manual to the letter - where are they going to find such useful GDI engine maintainence tips you reference ? … They aren’t. The auto makers do not want to show any additional maintenance in the OM that will increase cost of ownership (i.e. using 93 octane gas , CRC intake valve cleaner every 12 K miles, using higher quality oils , lower 3,000 mile OCI’s , etc.) as it’s bad for new vehicle sales and most GDI engine owners are not even aware of such GDI engine ownership best practices (it’s unfortunate).
I understand using better oil but why shortened oil change intervals? I would have expected a small early "flash off" from fresh oil. Is that offset by fuel in old oil, or what?
I don't know which would be better for the GDI intake valves - longer or shorter oil change intervals. And why?
Fortunately I've avoided GDI thus far and hope to keep it that way.
Shorter OCI’s (3,500 - 5,000 miles with typical mixed driving) with a GDI engine are preferred due to the soot that GDI engines produce and end up in the oil . Oil filters don’t do much to remove soot which is abrasive and in higher concentrations can add wear to timing chains.
Using higher octane gas will do nothing for IVD of GDI engines! First of all, the fuel never even touches the back side of the valves where the buildup occurs. Secondly, when using Top Tier fuels as recommended by a lot of manufactures these days, ALL octane grades of fuel MUST meet Top Tier standards.
What gas stations do not offer the proper fuel required for modern engines? All the fuel in a given area, come from the same place. BP does not have their own gas storage area, nor does Shell. One refuelling truck goes to a shell, a BP a Sunoco, a 711 and a QuikTrip.
I know. However, they all have their own proprietary detergents which are added to the fuel upon delivery.
There is EPA level and then there is Top Tier levels......
https://www.aaa.com/AAA/common/AAR/files/Fuel-Quality-Full-Report.pdf
It's all about the additives that are added.
There's a BP at 15 Mile and a No Name station across the street. The No Name also states it gets the BP hauler to serve them. But what's inside that hauler's tank at No Name is a different, lesser additive blend.
Some vehicles get by on cheaper blends. Others need more. Some vehicles show rough idles at 20k - some don't using the same exact gas. Do a 20k experiment at each. That will give you a better answer to their ratings, as seen fit by your specific vehicle.
I've been using Top-Tier for over 25 years now. If BP doesn't want to pay for the Top-Tier Licensing, then I'll shop for gas elsewhere.
