I just bought a 2013 optima that has the 2.4L GDI engine. From what i understand there are some serious considerations when it comes to choosing a motor oil. Mainly: Sulfated Ash, NOACK volatility, and short OCI's due to fuel dilution.
I was convinced that quick OCIs of 5K with PYB was the answer but all conventional oils have a NOACK of >14 with 10w30s usually the best of the grades.
PP or QSUD has better NOACK but seems a little crazy to run PP 5K miles
PU has by far the best NOACK of any OTC oil that i can find but for 27 dollars i just cant see running it for 5K miles.
Im considering M1 0w40 but NOACK is higher than PU and ASH is a little higher.
I believe this is only the 3rd year for this engine design. I cannot find a lot of information on this engine as far as carbon build up issues so im not sure if they exist or not. I have read that GM has one the best DI designs but not much out there on the Kia Theta 2 engine.
If anyone has any direct experience with this engine, i would really appreciate your opinions. I believe it comes with 5w20 dino from factory which would be about worst case for NOACK. Hopefully this is a good engine and will not have issues with injectors or carbon buildup. I have read some issues with injectors and them needing replaced. Also running top tier gas is also recommended which i guess would be Shell or something.
Im leaning toward PP / QSUD 10w30 which gives by medium price, good NOACK and a great oil for 5K changes.
