"This is the biggest balloney af all times! Citgo wants you to fill up and add make-up oil of Citgo brand name only. No such thing as additive clash or the like.....as Citgo implies here. When is this myth going to die???"
"It is certainly true that there are additive technologies and synthetics combinations available that could cause incompatibilities," Miller says. "But Shell does not use them, and I know that if that ever changed, we would be sure to keep everyone very well informed." At the same time, it's important to understand just what constitutes incompatibility. "Incompatibility of engine oils refers to observations such as additive dropout, or changes in fundamental oil performance that's not what one might expect from mixing two different oils together," Miller says. "But naturally, if you mix oils with different characteristics, you're actually blending those characteristics - you've changed some of the features of the oil."
http://www.shell.ca/code/motoring/encyclopedia/motoroil/synthetic_oils.html
"The oil industry only runs a few lab tests to make sure additives are compatible when different brands are mixed. However, no engine tests are run. Nor are tests done to account for all possible oil brand combinations...If you mix two brands, you may get the worst of both worlds, instead of the best."
http://www.rotella.com/qa/answerresult.php?rowid=25
"It is always advisable to not mix motor oils, however, different viscosity grades of the same motor oil are compatible."
http://www.chevron.com/prodserv/nafl/auto/content/faq.shtm
[ December 15, 2004, 01:27 AM: Message edited by: TC ]
