I know this is old news, I'm posting this as a reminder since Fram still advertises Extra Guards as having silicone ADBV's.
O boy here we go..........................burn baby burn....................How are you determining that nitrile is used?
I would agree…As long as the nitrile does the job there should be no worries.
It will do the job fine but over longer periods of time the valve will stiffen and lose some sealing abilities.As long as the nitrile does the job there should be no worries.
True, my issue is with them being advertised as the better for extended OCI’s silicone. Maybe a sticker on the box for the nitrile ones .As long as the nitrile does the job there should be no worries.
Big deal. If we didn't hang around here we wouldn't know the difference. It is a 10k filter and the nitrile ADBV will work for 10k. I think they are doing the best they can to keep things going. They moved production to the US, too, so I'm going to cut them some slack.True, my issue is with them being advertised as the better for extended OCI’s silicone. Maybe a sticker on the box for the nitrile ones .
Go burn some ADBVs yourself and you'll find out. Guess you missed the threads where the claimed black "silicone" ADBV in the Fram filters burned just like nitrile. Silicone and nitrile rubber don't burn the same ... not even close.My question was "How are you determining that nitrile is used?" You can't tell solely by the color. When I ran elastomer compatibility with oils and greases, the nitrile and silicone were usually both black. Either the supplier needs to verify what the elastomer is or you need to run tests to make the determination. Orange doesn't mean silicone and black doesn't mean nitrile.
Yep, a reasonable and acceptable explanation. Unfortunately, not the one that came from FB/Fram reps. Instead, it was old vs new stock, and later the "black silicone" explanation. The latter now proven inaccurate multiple ways. Nitrile showing up on the orange can one thing, then showing up on the 15k rated TG, another.Shortage of silicone in industry and we can't get the silicone parts/gaskets/seals/components/fluids like before covid. .....
