Wut … Then I don’t have to dig for a nice calculator …
(I do have to calculate lift forces once in a while) …
Of course the real easy way is: hey Steve, how much ?
A decision is a decision, stick with it. You are fine as you are, bullies can try to dominate you and say you are not fine as you are, but you are stronger. I’ve seen how you stand your ground, ++++++ The whole thing here is not that serious, people end up trading the car or it rusts out and there goes all that oil filter hand wringing with it.
Good thread, look how it lasts.
It was rhetoric ... because the fact is, the flow volume is the same any time the PD pump isn't in pressure relief, so "More holes mean more volume but lower oil pressure" isn't ever going to happen. The oiling system on an engine isn't like the water system in your house.
Because crank and rod bearings are the main components in an engine that determine what the oil pressure is. The oil filter has no effect on engine oil pressure unless the oil pump is in pressure relief, which is hardly ever.
