gathermewool
Site Donor 2023
Easier to use .7854 which is a clockwise group on your calculator
Boooooooo, everyone boo this man!
Wut … Then I don’t have to dig for a nice calculator …Boooooooo, everyone boo this man!
(I do have to calculate lift forces once in a while) …
Of course the real easy way is: hey Steve, how much ?
What?Why is more better? More holes mean more volume but lower oil pressure. I pick the filter that came on the car from the factory.
So if there's too many holes your oil pressure might go to zero ... ??Why is more better? More holes mean more volume but lower oil pressure. I pick the filter that came on the car from the factory.
No, the filter media itself offers some resistance to flow so it will never be zero unless you have a major leak.So if there's too many holes your oil pressure might go to zero ... ??
It was rhetoric ... because the fact is, the flow volume is the same any time the PD pump isn't in pressure relief, so "More holes mean more volume but lower oil pressure" isn't ever going to happen. The oiling system on an engine isn't like the water system in your house.No, the filter media itself offers some resistance to flow so it will never be zero unless you have a major leak.
So why on some engines with excessive bearing clearance i.e. like a major leak, is the pressure low?It was rhetoric ... because the fact is, the flow volume is the same any time the PD pump isn't in pressure relief, so "More holes mean more volume but lower oil pressure" isn't ever going to happen. The oiling system on an engine isn't like the water system in your house.
Because crank and rod bearings are the main components in an engine that determine what the oil pressure is. The oil filter has no effect on engine oil pressure unless the oil pump is in pressure relief, which is hardly ever.So why on some engines with excessive bearing clearance i.e. like a major leak, is the pressure low?
