This is for the Yamaha Roadstar 1700cc air cooled V-Twin and I have three choices available to me, but none are ideal. So which would you use?
First, due to the flat tappet cams, I need an oil with at least 1200 PPM ZDDP. Also, I'd Ideally like a JASO rated oil for the wet clutch that shares oil with the motor. [But I understand some non JASO rated Rotella oils still work fine.] And since the weather is getting hotter every year, and temps frequently exceed 110°F, with a very hot running air cooled motor I'd prefer a high enough viscosity rating to handle ambient temps up to 120°F.
The three Rotellas available to me are:
T5 10w30- semi synthetic, JASO rated, but the viscosity is only rated up to 95°F ambient temp,
T5 15w40- semi synthetic,*not* JASO rated, but the viscosity is rated up to 104°F ambient temp.
T6 5w40- *full* synthetic, JASO rated, the viscosity is rated up to 104°F ambient temp, but VOAs show ZDDP as low as 1050 PPM
[Both T5s are around 1200 PPM per VOAs.]
So what say you?
Note: There is a T6 15w40, but at it's price point, I'd just assume stick with Mobil 1 V-Twin 20w50. The whole reason I'm considering Rotella is because M1 V-Twin runs $10-$13 a quart depending if it's on sale.
Thx for the input,
So what say you?
Thx for the input,
