Originally Posted By: crazyoildude
IM not so sure what Pennzoil has anymore.. We will find out soon when PQIA does their thing because i don't think Pennzoil listed a late 2016 PDS .. But if im wrong please post it.
We've been through this before. Why do you need a new data sheet? We're still on SN/GF-5. Pennzoil conventional still meets all the same specifications that it did two years ago, and longer, even. So, if nothing has changed, Shell has not had an overriding reason to significantly reformulate. If they haven't significantly reformulated or changed approvals, there's no need to update the data sheet.
What are you expecting to see different? Virtually all ILSAC oils of the same grade are far more similar than they are different. If we're talking PYB 5w-30, I'll tell you what you'll see, and what you won't see. They may not show HTHS, but you know it will be 3.1 +/- 0.1. VI probably won't be too far from 160 to 165. KV40 and KV100 will be low nominal for the grade. Phosphorus won't be listed, but we know where it will be, pushing at the upper limit. MRV, CCS, and pour point will be middling for the grade among conventionals and not be challenged whatsoever by your winter climate. It'll have the basic Ford spec, the Chrysler spec, and they may note the obsolete GM conventional spec. Other than a Pennzoil logo and some contact information, that about covers it.
