I recently got a '99 V6 Ford Ranger with over 200k miles. Service records are adequate, and the oil in it is a conventional and time for a change. In park or neutral it idles about 1000 rpms and quite smooth but in gear under load while stopped the rpms drop to about 700-800 and the idle shakes a little. It is definitely more rough. It also has a "hiss" (not quite a tick, more like a whoosh, whoosh, whoosh) that increases with rpms or speed. It doesn't sound metallic, more like rushing air. In my research it might be manifold related, exhaust, I'm just not sure.) I'm fixing to change the oil/filter. Any feedback on which would be a better choice? On hand, I have:
* Valvoline Syntech
* Pennzoil Platinum
* Kirkland
* Quaker State High Mileage
* Mobil 1 High Mileage
* Chevron Supreme blend
I'm leaning toward using one of the High Mileage oils, which may condition any seals in this old gal. Also would you use an engine flush on this unknown truck?
* Valvoline Syntech
* Pennzoil Platinum
* Kirkland
