Usually the hood will droop a little on the bad side, but (as said above) the other one is likely going too. Wonder how much cheaper they are to build than springs?
Lift the hood mid-range then quickly yank it up and down about six inches. The one on the "good" side will offer more resistance while the bad one will feel more floppy.
Definitely shop around, it's the kind of thing that they overcharge for when bought locally.
In Guatemala my dads mechanic took a giant channel lock pliers and pinched the strut a little below where the shaft enter the housing and it has been holding the hood up now for another 4 years...
Originally Posted by bullwinkle
Usually the hood will droop a little on the bad side, ...
That's by far the easiest way to tell, if they really are unequal. If it doesn't "droop" on its own, you can feel which side is weaker by twisting the hood (or hatch or whatever) slightly.
Posted a comment HERE about a neighbor who had been using a stick/board as a prop. Worked out badly for him. Since that post, he's suffered a stroke that affected cognitive skills. Doctors said unrelated to head trauma he suffered, I'm unconvinced. He's very gradually recovered some skills but is no longer allowed to drive. LHS now sold.
