Trav
Thread starter
I got the VDO with sending unit. First of all it is a mistake that it is priced lower than the VDO without so its a deal from the get go, secondly it is actual OE with the OE symbols and info ground off. Both Pierburg and VDO were both used OE.
The original.
The replacement.
The Denso is a ripoff in comparison, it is a Pierburg same as the Hella with a huge Denso brand up charge, the Delphi is cheap chicom crap with a Delphi name up charge.
The OE pump from the dealer is over $400 and is identical to the VDO also made in Germany. I didn't bother with the Bosch as it is not an OE supplier for this car and is Chinese made also.
Vdo
https://www.opticatonline.com/part/hskv-0-continental-228233001003z?ctx_q=228233001003Z&ctx_iam=1
Hella
https://www.opticatonline.com/part/...-by-hella-700468840?ctx_q=700468840&ctx_iam=1
Denso (same as hella
https://www.opticatonline.com/part/bbnf-3d-denso-auto-parts-9533064?ctx_q=FG0416&ctx_iam=1
Delphi
https://www.opticatonline.com/part/bbmx-0-delphi-fe0723?ctx_q=P76730M&ctx_iam=1
Bosch
https://www.opticatonline.com/part/bbhk-0-bosch-69740?ctx_q=BOSCH+69740&ctx_iam=1
OE part
https://parts.vw.com/p/Volkswagen_1...mbly-Electric-Module/48584862/1J0919087J.html
Aftermarket price for VDO
https://www.oreillyauto.com/detail/c/vdo/vdo-fuel-module/vdo0/228233001003z
https://shop.advanceautoparts.com/p...pump-module-assembly-228233001003z/11641447-P
The one from FCP does not include the sender.
https://www.fcpeuro.com/products/volkswagen-fuel-pump-assembly-jetta-beetle-golf-1j0919087j
The original.
The replacement.
Vdo
Hella
Delphi
Bosch
OE part
