i have a 2003 ford taurus with a 3.0 vin code u vulcan. I recently aquired 2 different filters from an estate sale , probably as a throw in in a box lot. I will probably use both ,but I thought one might be better than the other for the synthetic oil I am planning on using.
The 2 filters are :
a fram tough guard #tg-3600
A S.T.P. s3600 not an e-core
Here are the specs from each
Part Number: S3600
Weight: 0.55 lbs
Anti-Drain Back Valve: Yes
By-pass Valve: Yes
Filtering Material: Advanced Micro Pore Technology Filter Media
Gasket Material: Rubber
Non Slip Grip: No
Oil Filter Diameter (in): 2.96
Oil Filter Height (in): 4.44
Oil Filter Type: Spin-On/Canister
Removal Nut: No
Part Number: TG3600
Weight: 0.55 lbs
By-Pass Valve: Yes
Diameter (In): 2.98
Height (In): 4.92
Filter Type: Oil
Filtering Material: Cellulose/Synthetic Blend
Gasket Material: Nitrile Rubber
Non Slip Grip: Yes
The 2 filters are :
Part Number: S3600
Weight: 0.55 lbs
By-pass Valve: Yes
Non Slip Grip: No
Removal Nut: No
Part Number: TG3600
Weight: 0.55 lbs
By-Pass Valve: Yes
Diameter (In): 2.98
Height (In): 4.92
Filter Type: Oil
Non Slip Grip: Yes
