Relief valves necessary?
USA
These 2 filters are for a Toyota 1mz-fe. 1 has a relief valve and the other doesn't. Is the relief valve necessary?
http://ecat.arvinmeritor.com/smartlink/?partnum=pl24457 pl24457 pureone
Type of Filter: Spin-on
Thread Pitch: UNF-2B
Anti-Drain Back Valve: Yes
O.D.: 2.98
Threads: 3/4-16
Height: 4.02
Relief Valve P.S.I.: None
http://ecat.arvinmeritor.com/smartlink/?partnum=pl10241 pl10241 recommended
Relief Valve P.S.I.: 12-17
O.D.: 2.98
Threads: 3/4-16
Height: 3.36
I'd have to challenge the one that you say has no bypass valve.I would by one and cut it apart to verify...it must have one!
Is that the correct filter for the application?
Or are you picking an oversized option?
What year and model?
Bypass valve is necessary if engine doesn't have one built in!
The pl10241 is the recommended size the other is an oversize. 2000 Toy Avalon 3.0L 1mz-fe engine.
You risk breaching the media in certain circumstances. It's probably a very rare occurance ...but
T-Kieth has the correct answer.
Without a by-pass you risk reduced oil flow under certain conditions and finally a collapsed element if the pressure becomes to great--within the filter. Once the oil filter collapses you no longer have a flow problem through the element but then again you have no filtering...and you won't know until you remove the filter to check.
Well, I checked and the Toyota oil pump does have a bypass valve as does a Toyota filter.
Why would a current Pure One filter NOT have a bypass valve?
I looked up applications (136) for the PL24457 and most of them were Nissans, Suburus and VW. No Toyotas.
PL24457 does not appear to be for Toyota applications.
PL10241 is used for some Lexus and Toyota applications.
The statement that these "2 filters are for a Toyota 1mz-fe" does not appear to be correct.
PL10241 is the correct filter for a 1mz-fe, and in common with all Toyota filters, it has a bypass valve.
Thanks for all the help
I assumed that all current car oil filters had bypass valves.
Some OEM's have their cars with the pressure relief valve built into the engine block and that is why some filters are manufactured without one.
It's is best to always verify how the OEM filter is constructed and choose your replacement filter accordingly.
WRONG, WRONG, WRONG.
The oil pump has a pressure control valve. It limits the max oil pressure the pump puts out. Any excess oil is dumped back to the sump.
The oil filter (or the filter mount on GM engines) has a high differential pressure bypass valve. If the pressure differential between the filter inlet and the filter outlet exceeds the limit, the oil is sent to the engine unfiltered.
NOTE THAT THE FILTER BYPASS VALVE SENDS OIL TO THE ENGINE...THE OIL PUMP PRESSURE CONTROL VALVE DUMPS OIL TO THE SUMP.
Ken
