Stock oil pump? The amount of HP doesn't matter, it's about how much max flow the pump puts out near redline. Any known brand name filter like the mentioned MicroGard (get the Select, 10K model) or the Carquest Premium or Carquest EP would work well and have very good efficiency. If you don't care about efficiency, then go with something like the WIX XP, Purolator BOSS or the Purolator 20K (gold can, and Walmart only). The new Mobil 1 at Walmart would be good too, and in the middle of the efficiency range of off the shelf filters.
