IMHO it's a waste of $$$ to use a high end filter on conventional motor oil, assuming that the filter gets changed at the end of every OCI.
Knowing that even the cheepest Fram has sufficient multi-pass filtering efficiency, I would just stick with a shorter OCI with conventional motor oil and then use the cheapest yet effective OTC oil filters.
Afterall: I believe in shorter OCI with conventional motor oil than those botique fancy OTC oil filters, given all else equal.
