I have used Amsoil 0W-30 since 1996 in my truck. I currently have it in my 2001 GMC SLT Extended Cab Z71 with 35,600 miles. My buddy has my old 1996 Chevy Z71 and he has over 100,000 miles using 0W-30.
Yeah, it's marketing. The 0w30 Castrol is quite a bit more expensive than other oils in Europe (50 pounds for 5 liters in the UK, which is about $15.00 per quart), but I think Castrol knows that if all the other Syntec on the shelves in the US is 4.99 and the 0w30 were 6.50 (let alone $15.00), nobody would buy it. I'm sure it's the same with Mobil 1. The 0w30 and 0w40 are no doubt more expensive to make than the other grades, yet Mobil holds the price on those grades to the level of the others. (For price comparison, in the UK, Mobil 1 0w40 is about 30 pounds for a 4 liter jug, or 7.5 pounds per liter. Castrol 0w30 is about 10 pounds per liter.)quote:
Originally posted by Judd:
Just checked another local AutoZone, they got the new Castrol 0W30. Think I'll try that when I get to the end of the 0W40 M1 interval.
Wonder why they charge the same price for what must be a higher cost product? Not gripeing at all, just wondering. Marketing issues?
This oil meets the toughtest VW/Audi standards, so I wouldn't hesistate using it if I had a VW turbo. Keep in mind it was VW and Castrol working together that spearheaded the A5 standard in Europe for low friction, low HT/HS oils, all of which are 0w30. Castrol makes a version of the SLX which is A5 specifically for VW and Audi engines that call for it. Since the Syntec 0w30 is an A3 oil with good HT/HS numbers, it should do fine in your turbo.quote:
Originally posted by VeeDubb:
You guys have gotten me all excited about this Syntec. I would love to buy some, if nothin else, to support Autozone stocking it. The only thing that is holding me back is:
1. I'll be driving the VW turbo in 110 F weather in Arizona this summer for extended periods and somehow, seeing that big "30" on the bottle rather than something heavier makes me nervous.
2. Our other car, the Volvo owners manual seems to warn against such a light oil in hot summer temperatures.
So I've got a few mental blocks to overcome.
We obviously don't know for sure yet, but let's assume in this case that the 0w30 Castrol holds it's viscosity very well, and stays at 12.1 cst throughout your interval. Wouldn't you rather run this oil than to run a 40wt oil that starts out at 13.0cst but then thins out to 11.5? I personally believe a well built 30wt oil can provide more than enough protection for most cars on the road today.quote:
5w-40 is the recommended weight. I am currently running valvoline synpower 5w-40 and the car runs well with this oil. About to send in an oil analysis on this to Blackstone.quote:
What oil does the owner's manual for your VW call for? [/QB]
Right here! If you go to the main page of www.bobistheoilguy.com there are many sections there which go into great detail.quote:
Originally posted by kiko:
HT/HS?
PAO?
Group III?
Please enlighten this newbie. Where can I go to find out what all these terms mean? Thanks.
I just checked my Autozone again and the 0w-30 German stuff is $4.49 (along with the 5w-30) while the 10w-40 and the 5w-50 are $4.99! What is up with that? The more expensive oil is sold for cheaper? It's a strange brand of marketing.quote:
This is an endless source of debate on vwvortex and you'll get 10 different stories from 10 different people. To throw a wrench into the discussion, most service advisors I've encountered at VW dealerships recommend 20w-50 for the V6, presumably to slow the consumption. One thing I do know is that I have never heard of a VW dealer using the correct 5w-40 oil during an oil change on either the 1.8T or the V6 unless you request it and pay $$$ for it. They seem to use 5w-30 or 10w-30 dino on the 1.8T's and a heavy 20w-50 on the V6's. Anyways, that probably doesn't answer your question about what to use, but I don't think I have ever gotten a straight story on this. I will have a sample of Valvoline Synpower 5w-40 coming in soon and I'll post it when I receive it.quote:
Originally posted by VAG Mark:
I also just bought a new V6 Passat and while the first change is a while away, I am open to suggestions for a good oil for it. BTW the history on VAG's 2.8 V6 says its known to use oil. The reco weight/spec is the same as my 1.8T for 2003: 5W40 if avail, but 5W30 is OK too. This is based on an INSERT to the owner's manual, which comes back to wording used 3 years ago. From 2001 to 2002 it says use 5W40 only. 5W30 is OK only for topping up!!
Those discussions on vortex get quite heated with a lot of people asserting strong opinions without facts. Nonetheless, some of those discussions are entertaining. I wish I can offer you advice on your oil consumption issues. I've heard about the problems with the V6's but I own a 1.8 so I haven't paid close attention. I recall that somebody here had said that they were able to reduce their oil consumption using Redline, although my memory is foggy. You may want to check the archives on oil consumption and redline to confirm this. Anyways, that's an oil you may want to look into.quote:
VeeDub, I've read the endless discussion on both vwvortex and clubb5 on this topic and yes, there's lots of conflicting views.
I've used Amsoil 0w30 in both my F150 and my VW TDI which is also turbo charged with no problems. This was when I lived in El Paso texas, so I've seen temps over 100 many times.quote:
quote:
Race-proven technology designed for passenger car performance. Provides unsurpassed fuel efficiency and up to twice the wear protection provided by popular conventional and synthetic motor oils. Recommended for use in all vehicles requiring 5W-20, 5W-30 or 10W-30 motor oils
