for a Honda S2000 2.0L motor?
I've narrowed it down to either Motul 300V Power, Redline, or Amsoil but the numbers on the spec sheet have me at a bit of a dilemma.
Here are each of the three in detail:
Motul(the ubb wouldn't allow a direct link because of parenthesis in the url so you'll have to click here and then click on 5W-40 to bring up the spec sheet)
http://www.motorspot.com/racingoils.html
Redline
http://www.redlineoil.com/pdf/4.pdf
Amsoil(click and scroll to bottom)
https://www.amsoil.com/storefront/afl.aspx
The motor has approx. 22k miles and has had Redline's 10W-30 in it for about the past 5k miles. The previous owner said that he switched over to the Redline at around the 12k mark and ran the first batch until 17k; which is why I'm thinking it might be good to go ahead and change now at 22k and get a UOA to see how things are going. Honda specs either 10w-30 or 5W-40 for the motor and since I'm having some minor consumption, about a half quart every 3k miles, I thought I'd try a 5W-40 to see if it slows that a bit.
Based on the numbers from the three above I'm concerned with the thickness I see in the Redline. I like the Amsoil's numbers but I'm apt to stick with an ester based oil since the Redline is in there now. I could be talked out of this though.
The Motul's numbers look extremely good as well which is why I'm having this debate. I think the only thing that has kept me from ordering the 300V Power before now is it's lack of availability online.
I also took a look at Mobil 1's 5W-40 spec sheet but the numbers are even higher it seems in terms of thickness when compared with the Redline; but, perhaps I'm more worried about thickness than I need to be. Ironically it's the only oil they suggest if you go through their suggestion wizard. They've stopped suggesting their 10W-30 for some reason...possibly due to its thinness?
The M1 is definitely the easiest and cheapest for me to obtain but it doesn't look like it stacks up as well as the three others.
On a side note, all of M1's oils at Wallyworld are $4.88/qt. here but the 0W-40, 5W-30, and 10W-30 are all offered in cases for $29.98 which equates to $2.49/qt. Has anyone been able to buy the 5W-40 by the case at the $29.98 price? The local auto section employee told me he wouldn't do it because there is no bar code on the shelf for the 5W-40 like there is for the other three. Does that make any sense to anyone else? Why would I pay double for the 5W-40 when all the other grades are the same price per quart?
Redline
