You may want to look at Mobil Delvac 1 ESP 0w40.
https://www.mobil.com/en/lubricants...-lubricants/products/mobil-delvac-1-esp-0w-40
Did no one read the diesel part?
If you want a stout diesel oil that's readily available try mobil delvac extreme 15w40 or 5w-40.
The voa for the 15w40 has 1300 zddp and 1200 phos. Higher than euro grades. Higher hths of 4.1 too.
The 5w-40 is a bit lower at 1100 zddp and 900 phos but that's still fine. Unless it gets to below 0 just use 15w40.
Or right it's esp 5w-40. Mobil has now made esp an "advanced full synthetic" and 15w40 a regular synthetic on their site.There is no such thing as Delvac extreme 5w40.
I rather use a higher hths or thicker 0w30 over a thin or any 0W-40 meeting the same spec and with more vii.
However, 0W-30's are in general more or sometimes much more expensive than 0W-40's ... That's why I settle with a good 10w30. lol
speaking of the royalty on bitog, Mobil 1 Full Synthetic 0w40 "Euro" is always cheaper than Mobil 1 Extended Performance 10w30 which is one of my favorite oils with no European bells & whistles ... maybe they are trying to lure people in with cheaper 0W-40 prices but it has been like that for a few years. Maybe no one cares about 0W-40 and less demand and that's why it cheaper! Maybe vii are cheaper or maybe it's like EV, and consumers aren't biting yet!![]()
M1 anything is not cheap in Europe, 0W40 or otherwise.
He was planing to run 6k OCI in the other thread. How much do yout think a modern 0W-40 VII will degrade in that time..
WA/Seattle is also warmer then many parts of U.K.
https://weatherspark.com/compare/y/...-the-Average-Weather-in-Seattle-and-Sheffield
Better known as Debbie DownerYour previous thread seeking the best didn't get anywhere:
https://bobistheoilguy.com/forums/threads/discovery-3-2-7-tdv6-oil-reccomendations.371950/
Curious what your Owners Manual recommends.... and what vehicle & engine is this for?Hi there all.
Wondering what the best 5w-40 and 0w-40 options are out there on the market in terms of ZDDP levels with the best HTHS ratings, highest base number and general overall best engine protection.
Intended use is for a diesel engine without EGR and without DPF or DEF. Just a catalytic converter in the exhaust.
I've been looking at redlines offerings as they seem to be the highest in anti wear additives.
Anybody suggest anything else?
Many thanks!
The original landrover manual for the 2.7 tdv6 recommends a 5w30 meeting B1/B3 specifications. But I know these don't exist anymore. So I believe a A3/b3/b4 to be the replacement.Curious what your Owners Manual recommends.... and what vehicle & engine is this for?
Other than that, many here seem to recommend the Mobil 1 ESP for their light diesels.
I'm leery about using the ESP Delvac-1 with your catalytic converter system. But I haven't seen the SDS specs on the Delvac-1, so Trav might be right and it could be safe to run in yours.
i have used valvoline extreme blue 5w40 with success, and price is goodHi there all.
Many thanks!
A few people in the landrover community recommend running a 5w-40. So I thought a 0w-40 would be a little better for cold start given the colder climate in the UK most of the time.
Average temperatures in Devon, where I live in the UK range between 5 degrees C to 25 degrees C at this time of year. And quite often drop to 0-5 degrees C in winter. Not massively cold.
| PORSCHE C40 |
| MB-Approval 229.51 |
| MB-Approval 229.52 |
| GM dexos2 |
| VW 511 00 |
Hi there all.
Many thanks!
JH, do you know why the Mobil Delvac 5w40 and 15w40 do not meet the approval for the Ford Powerstroke 6.7, yet the Mobil Delvac 0w40 is approved for the Powerstroke 6.7?Did no one read the diesel part?
I cold start the car twice a day morning and evening driving to and fro from work. She does 15 miles each way before being shut off. I then do a fair bit of towing in the evenings etc dragging broken down cars about. I average 250-300 miles a week. Sometimes more.
The vehicle is a 2009 discovery 3 with the 2.7 ford lion tdv6 in it. 134k miles on it and I tow 3 ton with it probably at least twice a week. Gearbox oil temps are taken care of by an additional cooler mounted behind the grill and I regularly change the oil too.
I've looked into mobil 1 delvac but it appears to be hard to get in the UK. 15w I've been told is a little too thick as the crank bearings in the 2.7 are known to spin.
Just wanted to say, all of this help is greatly appreciated! I can't thank you guys enough!
I just checked and extreme 15w40 does meet Ford WSS-M2C171-F1, so maybe they updated their PDS. The 5w-40 doesn't but that doesn't matter much. Cheap Delvac 1300 can meet that spec, I doubt the 5w-40 can't because it's inferior.JH, do you know why the Mobil Delvac extreme 5w40 and 15w40 do not meet the approval for the Ford Powerstroke 6.7, yet the Mobil Delvac 0w40 is approved for the Powerstroke 6.7?
So I will take it you don't know why the Mobil Delvac 0w40 meets Ford's WSS-M2C171-F1, yet Mobil Delvac ESP 5w40 DOES NOT. And of note, if one goes to Mobil's oil selection site, the site does not offer any recommendations for the Powerstroke 6.7 manufactured after 2017.I just checked and extreme 15w40 does meet Ford WSS-M2C171-F1, so maybe they updated their PDS. The 5w-40 doesn't but that doesn't matter much. Cheap Delvac 1300 can meet that spec, I doubt the 5w-40 can't because it's inferior.
Op also mention of using it in a 6.7 PDS unless he deleted the emissions equipment. Just a 2.7l Rover Diesel
