. The grid is basically designed to run your A/C in hot weather
Years ago, back in the 60s, a lot of houses around here were built with electric baseboard heaters.
And more recently houses are built with heatpumps that have aux heat coils. My heat pump has 20kW of aux heat in it. I've disabled half of it so it's only 10kW, and I've further disabled it so it only comes on when the outdoor unit is in defrost.
But you take a not-so-well insulated house with a heat pump...that aux heat is going to run a LOT when the overnight low is 15-20F.
I have to assume that the grid is sized to handle a lot of houses running 10-20kW of aux heat during the night.
