Lucky you!
No. You would see thick grease in a circle pattern around the slip joint.Could over greasing the slip joint cause this?
The prep is the worst part. The anesthesia is great! A wonderful nap.Not yet. Just trying to come down from the brake cleaner fluid high at the moment. I used 1 1/2 cans. The Red Stuff.
Gonna take it out for a spin and come back pretty quick. Just started my colonoscopy prep 2 hours ago and my wife told me to not get
too far away from a toilet.
That is next on my list. Thanks!
Oh yeah. Racing stripe has arrived.Sounds like you are going to have 2 leaky rear ends soon.![]()
I’m lying on my side watching TV.Yes , you will have to sit out, the rest of this thread!
This.Clean it with degreaser and a stiff brush, maybe some brake cleaner. Only way to really identify where it's coming from.
But waking up was a little difficult. I thought my wife was a nurse.The prep is the worst part. The anesthesia is great! A wonderful nap.
Oven cleaner works best on gear oil in my experience. Brake parts cleaner doesnt work great on it. Dawn Powerwash foaming soap works well as well. Would not be the first Toyota truck with a rusted out cover. Cover can be welded on in truck but the housing needs to be stripped bare to clean up after cutting and welding. Good time to replace axle bearings and seals as well.I checked the fill today and it is full. Barely drips out when I remove the filler plug. So that relieves some pressure.
Got the vent tube coming from Modern Toyota in Winston Salem. I'll swap that out and see what things look like after that.
Brake Cleaner doesn't really do a lot in removing the Amsoil 75w/90 from the housing. I wish I knew something more powerful.
And I used the CRC Red Can. 1 and a half cans.
Sorry, sounds like you had both an upper and lower G.I?But waking up was a little difficult. I thought my wife was a nurse.
My stomach hurts when I cough and my upper lip is swollen. Maybe I need to get the video.
Oil Drip pan under the unit kerosene in gator aide squirt bottle and a bristle brush.I checked the fill today and it is full. Barely drips out when I remove the filler plug. So that relieves some pressure.
Sure did.Sorry, sounds like you had both an upper and lower G.I?
My doc uses propofol. Easy to see how Michael Jackson became dependent. I usually get annoyed when the anesthesiologist brings me around, lol.
Hope you're feeling back to normal, soon.
The breather tube was replaced and is dry. This is coming out around the upper connector attachment.Looks like its coming out from the base of the breather - rusted through?
