I Messed Up - But How Bad?
NH
I changed the rear axle gear oil in my 2014 F250 this week. I bought the truck used with 23k miles on it and now it has 43k. I assumed that it wasn't done before, but the bolts looked like they had never-seize on them and the fluid was relatively clean looking. During my change I used a Luberlocker gasket (no RTV needed) and a new Dorman diff cover.
I added nearly 4 quarts of Amsoil 75w-110 Severe Gear gear oil, which is roughly the same amount that drained out (about 3.5) to get to the point where it just dribbles out of the fill hole. I could have sworn that the owner's manual and Amsoil recommends synthetic 75w-110 but I read it wrong. Its 75w-140.
My truck is a daily driver mostly. I tow occasionally but limited to no more than 10,000lbs and maybe a few times per year at most. When I do tow, its at reasonable speed and usually local, but will be towing up to 150 miles on the highway this fall.
What does BITOG think? Dump it immediately? Run it until the spring and then change? Forget it and drive till the wheels fall off? I'd rather not waste expensive fluid like that, but don't want issues with the rear end either.
Used to be 90, I would run it until spring at least. Amsoil knows it used to be 90 as well.
If your towing use changes, or increases, go 140.
Good to know, thanks for the advice all. I began to over analyze a little.
Amsoil sever gear 75w110 is likely a better product than Ford's 75w140, which is pretty good already.
Many years ago I had a dealership change the 5 speed manual transmission fluid of a '92 (?) Ford Festiva . Found out they put gear oil in it instead of A.T.F.. Not long after that I did the fluid ( Ford A.T.F. ) change myself once ( or twice ? ) and no issues for the following years until it was totaled from a severe rear-end collision . So , may want to drain it out and replace .
i dont see it being a problem my 98 F-150 used 75-140 with a friction modifier so it does not sound like ford changed much in over 25 years.
