Where do you buy orings?
LavaRand
I need an o-ring for the idle air valve in my van. It's a pretty big one about 3 inches in diameter and about 3/16 thick.
They won't sell me just the o-ring, I have to buy a whole new valve for $100. Which is BS. So I'm trying to find an oring. But all the hardware stores around here don't have a proper oring cabinet, and if they do have orings, they can't even tell me what material they are, and they definitely need to be gas and oil resistant.
.... and they definitely need to be gas and oil resistant.
Problem with measuring the old o-ring is it may be stretched (at least for the diameter). Measuring the cross-section, what you're estimating to be 3/16", should be accurate. You could try and measure the o-ring groove if you have suitable measuring tools. O-rings are standardized too so get the best measurement you can and look up suitable sizes. As I said above, o-rings stretch so if you find a p/n that's slightly smaller I.D., you should be able to stretch it to fit and this is normal.
Why does it need to be oil and gas resistant ? This is part of the throttle body, isn't it ? It only see "air", I thought.
McMaster is typically the first place I look. I'm fortunate that their standard shipping is two days lead time. However, my experiences with o-rings for automotive applications is that in most cases, they're not a standard size. Honda is the worst for using non-standard size o-rings.
Harbor Freight o-ring assortments (I have two) are Buna-N (so they state) which is "okay" for most auto applications; I've used them in a pinch but most times what's in the box doesn't fit anything automotive related. But they come in handy on those pinche Delta faucets.
