Though when I tried to put some Redline SI-1 in my van, most of it ended up on the ground. Now I know better and bring a trans funnel. Bad bottle design meets bad filler neck design.
When I have about a quarter of a tank I go to the gas station and dump the additive in and then fill the tank. That way the ratio is right. By the time I shop and go home it is well mixed. It is about 10 miles to the station I use.
In our last 4 vehicles have used mainly Lucas UCL or a mixture of Lucas UCL and MMO @ the rate of around 2.5 oz per 10 gallons of gasoline.
I always add it @ the pump before pumping. Carry the small Lucas UCL bottle in our vehicles about 1/2 full and when down around 10 gallons stop at the station and add the stuff then pump the fuel.
We just have started seeing virtually all stations here now with up to 10% Ethanol stickers on the pumps (all grades) because being close here to Florida where they require it state wide with some exceptions for aviation or boat use.
Think that UCL helps and by putting it in before pumping gets it mixed up good.
I add MMO at about 2 to 2.5 oz per each 10 gallons of fuel. I can usually tell pretty accurately how much I need to add by looking at my fuel gauge. I put in the MMO at the pump, then fill the tank with gas. I understand this is the best way for mixing any fuel additive.
I generally add it at the pump, before fueling up. But I generally wait for the low fuel light to come on
Makes it easier to measure.
In fact, the majority of the additives will recommend this; adding the additive BEFORE fueling up....but I think SuperTech's Gas, Fuel Injector, and Carb/Injector cleaners state to fill up, then add it; go figure
Originally Posted By: hardcore302
I run straight additive.
You got the right display name.
The directions for Regane Complete say add to a nearly empty tank, fill, and run that treated tank as close to empty as possible before next refill. I add it at the gas station and generally follow that procedure.
That said, don't know as it makes a huge difference.
