What's your preferred tire pressure?
When I reported the numbers above, these are numbers which Discount tire set for the tires on my van. In fact they set the rear tires at 47psi and I told them thats too much. the PSI has nothing to do with the context. Moreover it's about the tires Discount tire is installing on the van. 245/40/R19's seems to fit just fine and are load rated to suit the van, the issue is no matter what PSi is in the tires they all look flat or extremely low.
As posted elsewhere on the oil forum, someone said that's what you get for mounting a set of "bro" wheels on your van etc.. In fact these 19'' wheels look respectable and not bro'ish at all. Then add in other sites like Bulter tire in GA have posted images of a 2016 TC with 20''s on that van. These 19's fill out the wheel wells nicely and make it look proportioned correctly. if one was to search other TC's with larger wheels one would see that most list what wheel and not what tires, because they can't find or mount the correct tires on these van.. or the tire they do mount are far below the load rating needed. The van needs at least an 98 load rating. Those other guys put 91-94 load rated tires on the van and we've already experience that with 95's
Otherwise if one has an issue with how Discount Tire is handling this, by all means call them. Had an interesting talk with a rep from bridgestone/firestone Sat he suggested that if we're having an over flex issue with these tires, we should try run flats and that's what we're going to do.
@CapriRacer is more qualified to answer this than I am, but what the tire looks like is immaterial, it's whether you are matching the load carrying capacity of what the OE spec'd, which can be determined using the load tables.
Even if it "looks" flat, if it is grossly overinflated, it's going to be twitchy, wear the centre and generally perform poorly.
As I noted, the 245/40R19 has a 1,477lb load carrying capacity at 36psi in XL:
Which, if your OE tires were P215/55R16 in XL, they also had a 1,477lb load carrying capacity, but at 41psi.
Let's be frank here, the Tech at Discount Tire isn't checking the load tables to determine the proper pressure and then advising you accordingly. Guy has probably never seen the load tables in his life.
And yes, if you are bothered so immensely by the appearance, going with runflats (which are hard as hockey pucks BTW) will likely "solve" that problem.
I have seen many lower profile tires that look low to me but when checked are actually good.
I have done the chalk test on some to see if it has even pressure. Very hard to go by the look.
Many people I know with run flats can not wait to get rid of them. The stiffer ride, poor wear, limited choices lead them to replace with non run-flats even if they need different rims.
My Jeep has RFT's and yeah, they are hard and ride is harsh as a result. My winters ride a lot better. It will be getting non-RFT's when replacement time happens.
Most cars that I've owned or looked at have a recommended tire pressure of 30-32 psi on the door frame. Just about every time I've gotten new tires, the tire shop fills them up to 35-40 psi, sometimes higher. What's your preferred tire pressure compared to the vehicle's recommendation? Do you factor in vehicle weight distribution when setting the front vs rear?
Personally, if they recommend 30 psi, I'll generally set them to about 32 psi cold (first thing in the morning when they're coldest). I try to check and adjust at least once a month.
What it says on the B post.
So we've come full circle.. meaning that we started out with 245/40/R19 Nokian tires on the van and didn't like them only because the "one" tire did not handle very well on wet roads.. but I've bene told that we're needing a tire with a stiffer side wall which leans us to believe that we need runflats.. which is not the case. we've set up an appointment to have a different Nokain tire installed on the van. The WR G4's are known to have a better wet weather rating than the One tires we started out with.. I've been meaning to take a photo of what the tires are doing while on the van.. just so others know what's been happening..
So in another week we'll try a set of the Nokian WR G4's on the van and if my chance these don't work out.. we'll try another set of tires but this time runflats as this is our only alterative. it's obvious Discount Tire is working very hard to find the correct tires for us and their try it before you buy it policy has allowed us to swap 6 different brands of tires already. I'm sure they can't wait to get rid of us..
I bet you are right! LOL!
So after 4 months of trying 5 different brands of tires we finally found one that works on the van. The issue was, no matter what PSI the tires are inflated to, they kept wanting to over flex with their weak sidewalls. The only tires that did not over flex, but failed on wet roads was the Nokian One tires. We're willing to give Nokian another chance and it paid off. We tried a set of their WRG4's and what a difference the handling was far beyond anything we've ever hand on any of our vehicle.. these tires want to grip the road no matter the conditions. So for the record, the Nokian 245/40/R19 WRG4's at 44 F / 46 R work perfectly on our 19x8.5 AXE CS Lite wheels.
I was taught in school to run 35 on car and smaller SUV tires. Larger pickup tires I usually check the door tag and sidewall and go with my gut. OTR tires are either 100 or 120 depending on what it's on. On my wrecker I sometimes back the drives down to 80 in the winter.
with E rated tires on a 4runner sized suv, i run between 30 and 40 depending on how I feel. 30 gives ok handling and super smooth ride, 40 feels like stone tires and only wears the middle but gives better handling and a little less drag imo
i don't care about wear, 10 year old michelin's seem to be unfazeable
and they aren't going to explode at the next pothole i tried that already.
  • Haha
Reactions: rcs
Usually 3-5 psi above door placard.
I look for a combo of wet traction, fuel economy and tire wear. Too much pressure and you usually loose wet traction. Too little and you loose economy. Either way can cause funky wear.
You hit it just right and you maximize all 3
When the tires wear down and its the last season for them in fall or spring which can be rainy I usually go closer to the door placard. When the tire is down to the last bit wear isnt a concern and a small drop in economy for 3000 miles is cheaper than tires.
A couple of pounds over. I think the jamb number is low for comfort, but mostly to afford more time before I have to add more.
  • Like
Reactions: rcs
I would think the chalk test is only good if you don't go over 1 mile an hour. The tire deforms at speed as rotational forces come into play.
