How many hours/miles does your truck/vehicle have? I'm seeking information on a Duramax specifically, but if you have data to add from other vehicles (gas or diesel, please do.
We have a 2016 Duramax LML, 3500HD.... Flatbed, nothing special. Bone stock, not deleted. This truck is used as a work truck/daily driver. It accumulates over 3 hrs of runtime daily, its average speed is 14.7 mph thus far. I ran the factory oil and filter for an entire OCI, until the OLM hit 0%. I ran the second oil change till the OLM hit 0% as well. Heres the breakdown:
*Bought new 12/23/16* Oil used (after factory fill): Delo 400 SDE 15w40 along with M1-303A or PF2232 filter.
OCI #1 (5/27/17) 7,684 miles, 534.5 hours. OLM=0%
OCI #2 (10/31/17) 7,404 miles, 491.8 hours. OLM=0%
In total, at the last oil change, the truck had 15,088 miles and 1,026.3 hours, giving me an average speed of 14.7 MPH.
By following the oil life monitor I am seeing OCI's of about 7,500 miles/ 500 hours. Should I be changing the oil sooner than this? These trucks have a relatively small sump, is a 500 hour OCI pushing too far on 10 quarts of (non-synthetic) oil?
A few things to note, this truck has daily short trips of less than 1 mile, and a fair amount of idle time. It is ran at operating temp daily, it averages just over 3 hrs of run time each day, 7 days per week. This truck is used regularly for towing/hauling as well as unloaded (passenger type) regular daily driving, it required 2 quarts of makeup oil during its last OCI.
I know this is the wrong place to ask, but what about servicing the transmission, GM says to change the fluid and (spin-on) filter at 45,000 miles under severe service. These transmissions are factory filled with Dex VI, and GM gives no recommendation on a basis of hours in operation. I'm thinking a drain/fill and spin-on filter change every 1500 hours or less with Dexron VI?
Here is what Allison recommends (using their fluids):
I'm thinking that I may have to service this truck more in terms of hours, instead of miles. From what I can gather, regular service implies something along the lines of 25-30 mph. I know that Ford specifies 25 mph as regular usage, so we'll use that as our number for arguments sake.
Now, lets take engine coolant for an example:
Recommended change interval, 5 years/150,000 miles. (150,000/25 mph = 6000 hours) (150,000/30 mph = 5,000 hours)
My actual usage (150,000/14.7 = 10,204 hours), or lets figure 1500 hours per year. (1500x5= 7,500 hours)
I'd love to hear what you guys think, If you want to see the oil filters from my 1st and 2nd OCI, see my thread
PF2232, M1-303A. Thanks!
