What's in your engines at the moment?
'03 Honda Civic 1.7L - 50/50 mix of M1 0w20 & RL 5w20 Napa Gold 1344 Filter
'01 Chrysler T&C 3.3FF V6 - 50/50% mix M1 5w30 & M1 Racing 0w30 Baldwin B2 Filter
Father-in-Law's '02 Camry 2.4L - 75/25% mix of M1 EP 5w30 & RL 5w20 Toyota OEM Filter
Mother-in-Law's '03 Corolla 1.8L - 75/25% mix of GC 0w30 & M1 0w20 Toyota OEM Filter
2001 Jeep Grand Cherokee- 10w30 Pennzoil
1999 Chevy S-10 4x4- 0w30 GC
2003 Honda Civic EX- 0W-20 Mobil 1
JD LT160 16hp Kohler- 0w30 GC
Sears push mower 6.5 B&S- 10W30 Syntec Blend
Polaris Watercraft- Polaris Premium Blue
All other 2 stroke- Mobil 1 MX2T
First time post, long time lurk. Here it goes...
2001 subaru outback 2qts0w-20M1,1qt0w-30M1,1qtow- 40M1,.2qt 15w-50M1TRi-SYN. Valvoline oilfilter
1997 TOYOTA Landcruiser current dealership fill
1994 TOYOTA Landcruiser Supertech semi-syn 5-30
and FRAM PH-8A
1996 FORD PSD Rotella 15w40 & FL1995
2002 FORD Excursion PSD Rotella 5w-40 & FL1995
1986 TOYOTA Landcruiser PENNZOIL 5w30 and
Hastings oil filter-changing to Shaffers 5w-40
1977 4600SU FORD Tractor 15w40 Rotella,
FRAM HP1 (3$) oil filter DOUH
1997 7740 New Holland Tractor 5w-40 Rotella and OE filter, going to post UOA later. also changing to Shaffers 5w-40 supreme
1989 TW-15 FORD Tractor 15-40 Rotella and OE filtr
1996 John Deere 955 Yanmar 5w-40 Rotella and OE
1986 Toyota SR5 turbo pickup Castrol 10w30
currently with blown headgasket, usually M1
Honda TRX 300 ATV- M1 20w-50 MXT2 & OE filter
Honda TRX 400 foreman Hondaline 10w-40 & OE
Honda TRX 500 foreman- still new factory fill
assorted push mowers-leftover M1 and Rotella
all two cycle mixed with STIHL high performance 45:1 and AMOCO 93 White gas, and a little Neutra
peanut oil in the deep fat fryer
olive oil in the wok
Mobil 424 and LT hyd fluid. tractors
Shell Spirax 80w-90 all applicable farm equipment
Motorcraft 75-90 syn. gear for trucks
Shell Retinax (various)
Mobil Syn ATF
I Promise NO MORE FRAM!!!
'01 Olds Intrigue - GC 0w30 and small amount of Valvoline Synpower.
'00 Acura 3.2TL - 1 qt M1R 0W-30, 4 qts M1 0W-40, A-Rx maintenance dose and small amount of Torco MPZ.
Scratch the S-10 oil.Dumped the Brad Penn and changed it to Pennzoil Long Life SJ/CH-4 today.Added a little sucks-up and LC for kicks.
1970 Dodge Dart Slant Six
Delvac 1 and Donaldson p169072 filter
1978 Plymouth Volare
Rotella 5-40 Donaldson p169071 filter
1965 Belvedere
Mobil 1 10-30, Baldwin b2-hpg filter
93 & 99 Taurus; Purolator oil filter, 2 qts Mobil 1 Truck & SUV 5W-40, topped off with Mobil dino 10w30 (Drive Clean ?), usually 3 qts.
03 Dodge w/Cummins - Fleetguard Stratopore oil filter, 2 gal Delvac 1300 15w40, 4 qts Mobil 1 T&S 5W-40.
73 Intl Pickup...5 qts of Havoline 20w50 and 1 qt of Torco SR-5 20w50. ST#16 oil filter.
02 Jeep TJ... 6 qts of GC and a Valucraft filter #8
Moms Sportage has 4 qts of Pennz 10w30 and a Wix filter.
My ATV has Delo 15w40 and 2 oz of Valvoline Synpower stuff.
Originally posted by rugerman1:
[QB] I know this is a repeat of earlier threads,just wanted to see what everyone is running at the moment.
2000 BMW 323 60K GC 0w30 @7500OCI
1996 Audi A4 2.8 12V 155K Maxlife synth 5w30@7500OCI
1995 BMW 530i 120K Rotella Synth 5W-40 @5000OCI
1996 ford taurus GL 5W30 valvoline maxlife dino w/fram extended guard XG3600 oil filter.
1995 chevy cavalier LS 5W30 autostar (valvoline) dino with fram extended guard XG3387A oil filter.
1989 pontiac grand am LE 5W30 autostar (valvoline) dino with castrol maxpro CM3970 oil filter.
2004 Chevy Colorado 3.5 4X4
Mobil-1 5w30 with 1-qt 15W-50
1999 Chevy S-10 4.3 4X4
Castrol Syntec 5w30 with 1-qt 20W-50
1994 Plymouth Voyager 2.5
(3) Havoline dino 10w-40 with 1-1/2 qt Havoline Synthetic 5w30.
4.5 HP Toro Recycler gets 15W-50 Mobil-1
98 expedition
4 qts redline 10w30
1 qt. synergyn 5w30
1 qt delvac 1 5w40 added to it is:
2oz. torco mpz
2oz. ep #132
2oz. luboron
6oz. lube contro
11oz bg's moa
same goes in the 98 lin. cont 32valve intec and 98 crown vic
i use fleetguard oversized lf3315 for lin and expy. also baldwin b281 filters...vic uses reg.size fleetguard lf3681...all these vehicles originally use the motorcraft fl820s filter.
