What would you do?
CA
I think I know what most would do on this site regarding my situation, but I thought I'd ask nonetheless.
I'm currently into my current oci 3800mi and was wanting to get to 5k before draining. I have a Suzuki Forenza and apparently you are supposed to change the drain plug gasket after every change, well I didn't and just noticed it was leaking ever so little. I have a fumoto valve waiting to be installed. I could tighten the drain plug, but do not want to risk stripping it as it's aluminum. So, I am electing to remove the bolt, install the fumoto, and refill. I'm debating on changing the filter - an ST will be taking the Pure One's place that is on there currently. What do you all think?
I'd run as is and just simple green the oil smudged area at 5K. I guess you may want to use something that is easier on the aluminum but I'd rather clean oil than replac ethe alumunium pan.
If it's just a tiny drip here and there, I'd tighten it just a smidgen. If you have a torque wrench you could work your way up to where it is and go a lb or two over. That's not much.
Otherwise, if the drip is a big one and you are really emotionally invested in your current fill, you could scrub out your collection pan (or maybe get a new one), scrub all the dirt and grit from around the drain plug, and drain it. Then pour it back in using a funnel and a paint strainer just in case there's a piece of grit in it.
My guess is that you are using non-synthetic. And you now have some 76% of the planned use of the oil. Assume $2 per quart, 5 quarts and a $7 oil filter---that's $17.
So if you drain it out now, take care of the drain plug leak, you'll have thrown away $4.08 of "good" oil and filter.
Golly, in some places that will buy you a beer!
I turn my gasket over each time, and end up replacing it about once every 4 or so oil changes.
If the sump is cold (i repeat only if its cold) and you have a quick hand, one can change the plug without loosing more than about 1 oz of oil. Involves holding your finger over the drain hole while you replace the gasket with the free hand. It's possible, ive done it! But dont recommend it
If plugs were that easy to strip, 90% of Walmart and other quick lubes(yes, probably me too) would be buying an oil pan with every oil change. Take a wrench and give it a little pull, then forget it till next due service.
Bob
Bob
Agreed.
The 3/8" Drive Bolt I removed from a Honda transaxle was so tight, the washer was literally welded to the plug. The 3/8" drive was almost rounded off. It took a 1/2" Drive (16" long) + 1/2 to 3/8" adapter, plus a lot of force to remove the plug. No damage to the threads as far as I can tell. I reinstalled it with 60-70 ft-lbs of force to get it to seal, as I had no spare plug/washer on hand. No leaks to this day...
Well, I decided to tighten it just a smidge, and see what happens... If its still leaking in a few days, I'll change it. There is not much dripping from it, as the dipstick still says its full. Thanks for the help!
