Do not get taken in by advertising hype. If your truck has only 60,000 miles in 44 years, it has spent a lot of time doing nothing. If it were my truck, I would run about 3,000 miles on Mobil 1 synthetic, 10W-40 High mileage. I would use a WIX filter, change it at 1500 miles, and then change oil and filter after the initial 3000 mile run. I would then continue with your OCI with the Mobil 1 10W-40 and WIX filter.
I have had new vehicles with the slant 6. I ran them with 20W-50 conventional with excellent results. The 10W-40 synthetic flows much better at low temp and protects much better at high temp. This particular Mobil 1 also has a higher ZDDP(1000)more antioxidants, dispersant's, MOLY boron and has some extra seal conditioners. Mobil 1 and Valvoline have seal conditioners, not seal swell agents.
If you do not want to go synthetic, then my suggestion would be Valvoline MaxLife 10W-40. It is a synthetic blend, has a good HM add package, but uses 300 ppm moly and keeps ZDDP at the 830 level. Do same as Mobil1 suggestion above, and continue your OCI after that initial 3000 miles.
