- Messages
- 5,287
- Location
- Paramount, California
Tribology Testing Labs developed an engine test called PCMO3 in 2015, which is used to predict fuel economy & engine durability.
http://www.tribologytesting.com/PCMO3-vs-Seq6E-vs-D7589-Jan2015.pdf
They claim:
For determining friction and wear characteristics:
• Gasoline & Diesel Motor Oils
• Relevant to All Engine Manufacturers and Models
• New Additives, Engine Materials, Coatings & Surface Finishes
• Idling, City & Highway Driving Sequences
• From Idling to 3000 RPM's
• Sorts by Viscosity Grade & Friction Modifier %
• Best Precision, Repeatability & Reliability in the Business
However, little detail is available about their actual test, which seems to measure fuel consumption and valvetrain wear on a test engine.
They tested several oils going back to SF, SJ, SL, and SM days as well as modern SN and dexos1 oils.
Some of the key conclusions:
* Despite the drastic reduction of ZDDP starting with API SL (1000 ppm P max) and then further with SM and SN (800 ppm P max), wear in general decreased with every newer API category. So, you don't need high ZDDP to reduce wear.
* Fuel economy of the newer categories is also much better.
* Perhaps, the most interesting conclusion is that the organic friction modifiers make a day-and-night difference in wear and fuel economy. The authors are blaming the industry for not incorporating this technology for many years and still counting.
* Used oil shows less wear than new oil (for the valvetrain), as it was discussed in other threads. However, the fuel economy of used oil is worse.
* Surprisingly, 0W-20 and 5W-20 has less wear than 5W-30 and 10W-30. This is probably because these oils are made with better additive packages and better base oils.
Here are the results. Note that the coefficient of friction and fuel economy are the same thing, related by a constant factor. It's interesting to look at oils from API SF days, when ZDDP was the king.
Sorted by wear, from least wear (smallest number) to most wear (largest number):
Sorted by fuel economy/coefficient of friction, from highest fuel economy (smallest number) to lowest fuel economy (largest number):
Code
Frict. Fuel ec. Wear Oil 0.218 3952 6.1 5W-20 SN used oil (9539 mi, Ford Fiesta) 0.120 2169 6.3 Reference oil 0W-20 0.101 1834 6.5 M1 5W-30 + 1.5% FM 0.171 3102 6.9 5W-30 SN dexos1 used oil (7500 mi, Chevy Avalanche) 0.204 3693 7.0 Valvoline 10W-30 SN 2015 0.168 3047 7.0 GM 5W-30 SN 2015 0.196 3540 7.0 5W-20 SN new oil 0.210 3805 7.1 Mobil Super 5000 5W-30 SN 2015 0.108 1943 7.2 M1 5W-30 + 0.75% FM 0.218 3939 7.2 Quaker State 10W-30 SN 2015 0.196 3557 7.3 SAE 30 SN 0.171 3092 7.4 Mobil Drive Clean 5W-30 SL 2004 0.176 2185 7.5 Mobil Clean 5000 5W-30 SM 2010 0.183 3309 7.6 Reference oil 20W-30 0.125 2274 7.6 M1 5W-30 + 0.5% FM 0.228 4124 7.6 Valvoline 10W-30 SF 1988 0.172 3110 7.7 Reference oil 10W-30 0.178 3989 7.9 GM 5W-30 SL 2001 0.137 2478 8.1 M1 5W-30 + 0.25% FM 0.150 2723 8.3 M1 5W-30 SN 2015 0.150 2723 8.3 5W-30 SN dexos1 new oil 0.189 3434 8.8 GM 5W-30 SJ 1996 0.219 3973 8.8 Quaker State 10W-30 SJ 1996 0.187 3393 8.9 GM 5W-30 syn blend SN dexos1 2015
Code
Frict. Fuel ec. Wear Oil 0.101 1834 6.5 M1 5W-30 + 1.5% FM 0.108 1943 7.2 M1 5W-30 + 0.75% FM 0.120 2169 6.3 Reference oil 0W-20 0.176 2185 7.5 Mobil Clean 5000 5W-30 SM 2010 0.125 2274 7.6 M1 5W-30 + 0.5% FM 0.137 2478 8.1 M1 5W-30 + 0.25% FM 0.150 2723 8.3 M1 5W-30 SN 2015 0.150 2723 8.3 5W-30 SN dexos1 new oil 0.168 3047 7.0 GM 5W-30 SN 2015 0.171 3092 7.4 Mobil Drive Clean 5W-30 SL 2004 0.171 3102 6.9 5W-30 SN dexos1 used oil (7500 mi, Chevy Avalanche) 0.172 3110 7.7 Reference oil 10W-30 0.183 3309 7.6 Reference oil 20W-30 0.187 3393 8.9 GM 5W-30 syn blend SN dexos1 2015 0.189 3434 8.8 GM 5W-30 SJ 1996 0.196 3540 7.0 5W-20 SN new oil 0.196 3557 7.3 SAE 30 SN 0.204 3693 7.0 Valvoline 10W-30 SN 2015 0.210 3805 7.1 Mobil Super 5000 5W-30 SN 2015 0.218 3939 7.2 Quaker State 10W-30 SN 2015 0.218 3952 6.1 5W-20 SN used oil (9539 mi, Ford Fiesta) 0.219 3973 8.8 Quaker State 10W-30 SJ 1996 0.178 3989 7.9 GM 5W-30 SL 2001 0.228 4124 7.6 Valvoline 10W-30 SF 1988
