What oil for a 07 GTI
Brickerville, PA
My brother called me tonight wanting to know what oil to use in his GTI. Its one of the newer ones with the 2.0 turbocharged 4 banger. He couldn't remember what they call for and he had the dealer do it the past couple times. He daily drives it in the fair weather months and does mostly car shows with it, but once in awhile he'll take it downt he 1/4 mile. Its chipped with an intake and turbo back exhaust. Anyways, I told him I figure it calls for a 5w-40. And I said i'm not up to date on VW specs, but if it were mine, I'd go with either GC, Rotella T syn., or Mobil 1 Turbo Diesel Truck. I think hes more than likely gonna go with the GC, but I wanted to double check with you guys.
I believe that VW spec's a 502 oil spec for that engine. I don't think that the GC meets this spec.
With the VW Turbo I would make sure it meets the VW spec or you could sludge up the engine very quickly!
The Euro/VW guys can confirm.
Pretty sure StevieC is right, it needs to meet the VW 50X spec. Mobil 1 0W-40 meets it. I also have friends in a VW club that use Amsoil Euro 5W-40 in their 1.8T, 2.0T, and R32's. One of my friends there has added a stage 2 kit and chipped his R32. very fast. and gets his Amsoil thru me.
On my friend's 07 GTI, we get it serviced with Castrol Syntec 5w-40 (VW 502.00 approved) every 10,000 miles at the dealer.
If you have the older 2.0T FSI motor, it is important to check your oil level regularly as high levels of oil consumption are not uncommon.
Any of those three are pretty good choices. The Rotella sounds interesting to me because of it's strong performance in subi turbos. The Mobil 1 Turbo Diesel Truck sounds interesting because of its higher HTHS and more ZDDP than Mobil 1 0W40. We don't have any used oil analysis on either of those oils yet on this engine that I know of. GC has shown some of the lowest shear rates in the database. We have over 40 used oil analysis on this engine and we know what it does to oils (beats the heck out of them in short order). This engine poses a unique challenge for oil due to the following factors:
1) Turbo Because this engine shears down even the best oils in a very short time, I would look at real world performance in used oil analysis first to see how much oils sheared and High Temperature High Shear (HTHS) performance second. Even the most shear stable oils are shearing in this engine.
VW 502 requires a HTHS of only 3.5 cP. I personally would use an oil with a higher HTHS viscosity than oils which are made to be just above the 502 minimum.
2) Fuel dilution This DI engine is a notorious fuel diluter. All oils have seen lowered flashpoint and thinning in this engine, it is only a question of how much.
3) Flat tappet type fuel pump follower and cam I would not use an oil with low amounts of ZDDP in this engine. Many recommend 1200ppm as a minimum for flat tappet engines and that may be a good rule of thumb for this engine (in the absence of more exotic additive packs that is). Typically a dealer may use syntec 5W40 which is fairly low in ZDDP as seen in this VOA:
Calcium 1053
Magnesium 926
Phosphorus 786
Zinc 918
SUS @ 210 70.7
Flashpoint 400 F
TBN 10.8
4) Deposits on intake valves, etc. from pcv system If he hasn't already taken measures to address this problem he should do so immediately IMO as this outweighs by far the choice of oil. Oil related factors related to this issue are cleaning ability and volatility. the problem is not due to the oil, however, it is a DI/design issue. Oil choice can only help slow down the deposit formation.
FWIW, I have been using redline 5W40 and the results have been good so far. It has shown some of the lowest shear rates, higher flashpoint retention, and lowest iron levels in the database. There doesn't appear to be a single magic oil for this engine IMO, only "different grades of destruction" ha ha. The fe numbers are shown in the graph below with some of the better than average "wear" used oil analysis identified (outliers of carradio's failing follower, adeere's 99% highway runs, and agpatels "who knows why there is so much iron with all oils on that engine" have been removed. Also many of these can be considered "single pass" used oil analysis and the data is on multiple units so take it with about a 55 gallon drum of salt). Also the Syntec 5W40 used oil analysis are shown in yellow just becasue that is an oil I was studying when I made this graph
GC was not on the list prior to early 09. The list that came out April 09 does have GC on it as 502 approved.
The only thing I can add to this thread is that these 2.0 turbo's seem to really destroy oil, so I'd keep OC intervals short.
That's why Rotella T 5W-40 is a good oil - very stout, but also cheaper than most other 5W-40's.
I'm usually an advocat of 'only use an approved oil while under warranty', but with VW's it seems their 'approved' oil often fall short, and you HAVE to go outside that to get good protection....
Sure it does. That's what makes it so great - it meets most of the key european mfg specs:
BTW, that info. was written on the bottle BEFORE it was on the VW approval list so it was not approved in the past but is approved after April 09.
This fact shows that the 502 approval is not nearly as meaningful as most people think (not saying u think that). Was GC a bad oil for VW's in March and then suddenly great for VW's in April? No way, it's the same oil!
Just trying to point out that people who blindly rely on the 502 specs and don't bother to educate themselves are taking too much on authority (not saying u r doing that at all but I see it all the time on VW forums). Many of the 502 oils are not good enough for the abuse this engine dishes out (like addyguy said). GC is a very good oil and one of the best 502 oils in the 2.0 FSI engine IMO. I will continue to use it in my non-2.0 FSI cars.
IMO, VoA just forgot to add it before - either they didn't thoroughly analyze what's available on the US market or somehow figured it wasn't easy to find here.
SLX 0w30 (what GC used to be called in Europe) has been a factory fill in many VW/Audi engines for years... even as far back as 2001.
