quote:
Originally posted by monarch:
joee12:
I do not use Toyota brand motor oil because Toyota has never stated it is the oil used as the factory fill. But I do use Toyota brand air, oil, and fuel filters and I use Toyota brand antifreeze and brake fluid because Toyota has said these are the factory original filters and fluids and because they cost about the same as equivalent aftermarket products available at auto parts stores (if purchased from an online Toyota discount dealer)
I have never worn out a brake caliper, wheel cylinder, clutch master cylinder, clutch slave cylinder or brake master cylinder after 417,000 miles using OEM brake fluid.
I have never worn out a radiator, heater core or even a cooling system hose after 417,000 miles of using Toyota antifreeze.
I have never worn out a fuel pump or had any fuel system problems after 417,000 miles of using Toyota fuel and air filters. Not even my fuel injectors have needed any attention or
additive to keep them clean. They must still be pretty clean as I passed a Calif. smog test just 4 days ago and my power and gas mileage has not deteriorated over the years.
I have never experieced an ignition system failure after 417,000 miles of using Toyota brand spark plugs, distributor caps, rotors and spark plug wires.
No, I do not work for Toyota. I sell agricultural chemicals for a living and rack up alot of miles being on the road making sales calls.
I thought this was a car care forum so I am sharing my experiences. My conclusion is
the Japanese engineers have figured out all the car durability secrets we need to know if only we were willing to follow their maintainance interval instructions and use the products they say are best to maintain our cars.
