what is the model number of this Delta Faucet
NorthEast
I went through almost 135 faucets on Delta website but could not find this faucet. I recall mine had some special temperature controls built in. I think it was supposed to keep the temperature constant and I think it was called "Monitor Series" but it has been 15 years! Now it has become extremely difficult to turn the small temperature control knob. And it has nothing to do with external lubrication. Believe me, I already tried Kroil etc :-(
Delta can help you identify it, they'll send you a new cartridge for free too.
I also realized that there is no access to change the faucet. I can't even see in the back of faucet to see if supply lines are soldered in or are threaded in. If I need to replace the entire faucet, I would have to cut a hole in the drywall on the other side. There is also not a shut-off valve for the tub/shower. Why can't there be plumbing code making this illegal? Or the reason for having plumbing code is to make sure plumbers can make lots of money?
Once Pex flooded the market, every Tom, **** and Harry became an "expert" plumber and the code got thrown out the window anyway.
Had a Delta Monitor in a previous house, this is from memory so I'd verify if I were you...turn main water valve off. The cap on the temp control pops off, there is a screw, remove and handle comes off. Remove escutcheon. The chrome piece under the handle pulls right off and you are presented with a brass nut. Remove nut and cartridge pulls out - you'll get pee'd on and the two rubber seats and springs will probably fly out.
You want to replace the seats and springs and there is a special lube you want to coat them and the back of the cartridge with or the handle will be tough to turn.
At 15 years there is a chance the brass seats on the rough in valve will be corroded and the entire thing will need to be replaced. This you have to cut a hole in the drywall and replace from behind, it will be soldered in.
Just went through that with my 18 year old Delta shower mixer. I was able to find all the parts from local suppliers. If you have to cut out the back buy a plastic paintable inspection door off Amazon. Then you can have permanent access and it looks fine.
I was able to clean mine up and used some plumbers grease to coat the inside of the housing so it turns like new. It's not rocket science.
That's a delta monitor, perhaps either a 1300 or 1400 series. They're pretty much "builder grade" faucets, but very simple to repair. The trim may be different but the internal components are the same.
Anti-scald technology isn't anything special-every bath/shower faucet is required to have it. It's been code almost everywhere since the late-1980s or early 1990s.
That's the absolute worst thing you could have used. Kroil will degrade the plastic and rubber in the cartridge and cause it to leak.
You should have used silicone faucet grease to lubricate any of the internals. However, there is just a screw that needs to be loosened slightly to make the temperature control easier to turn. It takes about 2 minutes, a flat bladed screw driver and a phillips #2 screwdriver to do it.
If you can't do something as simple as a drywall repair, then you most certainly should keep your hands off any plumbing. Leave it to people who know what they're doing.
I do not believe that is correct. That screw just removes plastic part from the stem. The actual turning mechanism is inside the cartridge body.
But would that give different symptoms? Or are you saying that new cartridge will not seal correctly even the the old one is sealed.
*** Thread resurrect ***
I am facing the same repair on my master bath shower. Only ten years in service since house was built and the builder, who enjoys a "premium builder" rep around here, used this low end builder grade fixture. Same in upstairs bath.
Problem with mine is loss of volume. It's been a problem with other fixtures in the house and changing out the shut off valves cured it, due to hard water. Guessing a cartridge replacement kit will do the trick, and going to hit up Delta for a free kit on warranty and see what they say. I'm getting about half the original (new) water pressure out of this thing. Not a household pressure thing because other fixtures are up to spec on pressure, something's fouling the cartridge in this I guess and obstructing flow.
If I was going to be staying here longer I'd get a water softening system installed, but I plan to be selling in a year or two.
