Originally Posted By: tig1
Originally Posted By: Shannow
Originally Posted By: DoubleWasp
20/50 is slow to flow under freezing conditions, but not a death sentence for an engine.
Pumpable, and it still gets there at the same time...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/36793/Shell_Helix_Sport_50_-_datashe
Maybe the same oil pressure, but not the same flow to the cam area. Much slower in very cold temps. Heavy oils can also cause the ADBV in the filter to prevent oil flowing through the filter for several seconds.
Note, we are talking the limits of 20W50, and my experience with 25W70 at -5 to -7C...not "very cold temperatures", where I always maintain that an appropriate for the weather conditions "W" grade be.
As to the continued "0W" equals flow equals start-up wear protection meme, here again is some testing that was done on an engine with a couple of different grades, in and around their lower temperature limits of pumpability.
At freezing, the SAE30 got full oil pressure, and flow to the rocker arms at 32F at exactly the same time as the 5W20 did at 10F...that's the mechanical filling capacity being filled with oil...when both cases were lowered, yes that case that you describe DID occur with oil pressure early and the rockers taking longer to get oil.
Again, this question is about what are the limits of operation of the 20W50 grade, NOT what oil is appropriate at "very cold" conditions.
MRV, the test for ability to flow to the pickup is at -15C.
CCS, the Cold Cranking Simulator is -10.
So I still stand by -10 as being the limit, and still stand by my statement that it's a grade that I don't use.
![Oil%20gallery%20fill%20and%20rocker%20time.jpg](http://i16.photobucket.com/albums/b42/akashafamily/Lube%20Stuff/Oil%20gallery%20fill%20and%20rocker%20time.jpg)
