Originally Posted By: Miller88
Originally Posted By: FordCapriDriver
People think 20W-50 Turns solid at anything below freezing , it's not THAT thick.... i'd be comfortable down to around -5 or -10c , ( around 15 or 20 degrees Farenheit ) , this is assuming you mean a conventional 20w50 , a Full Synthetic 20w50 could go a bit lower probably.
I was at a friend's house in the mountains last winter and during a cold snap we had a couple of nights where temps went as low as -12c which is very odd here , i had 20w50 conventional in the sump and after pumping the gas a few times it fired up ok.
Depends on many things and the engine in which I am running it.
I wouldn't run it in anything but extreme (100+ air temps) in my Jeep 4.0, for example. Those engines are known for having weak oil pumps as it is - combine heavy oil with something around 0F and I'm not sure it would lubricate properly.
Well your Jeep 4.0 and my Capri are two completely different animals , your jeep 4.0 likely specs 5w30 or 10w30 meanwhile my car specs 20w50 from new, a 15w40 HDEO is probably all it needs lubrication wise but the 20w50 helps with oil consumption and to maintain good oil pressure on hot summer days
