My limited experience with the Chrysler 3.8 (big brother to the 3.3) has been positive. Maybe were not thinking of the same engine?How about the 3.3 lol
Not sure what is to service an 24 valve Busso in the US but here they are reliable and will go distance. In fact there is a 330k km 147 GTA in my neighborhood. Original engine and gearbox.The 3.0 V6 24 valve Alfa has a terrible, terrible cam drive... The timing belt is simply overtaxed and will NOT go the distance. The sprockets are NOT indexed to the camshafts with woodruff keys. Timing the cams is a b*tch. By comparison, the 3.0 litre SOHC 2 valve per cylinder CAN be made reliable. That's my favorite Alfa engine. Need to keep an eye on the valve clearances... particularly the exhaust ones... and keep good fresh coolant in them (lest the iron barrels start corroding their aluminum block registers (wet liners)).
Probably worse than average..sludgemaster leading to timing chain failures. It was no slant six. Now there was a good engie. (IMO)Chrysler 2.7 is the best engine ever made ever...
In reply to Kristian and EdyVW - the 24V Busso showed up in the '94 and '95 164 here. The timing belt interval was 30,000 miles and the recommendation by Alfa was that at about 9,000-10,000 mi. after putting in place a new timing belt that the setting of the temperature-controlled timing belt detensioner was to be re-set at that point. They were very finicky to set up.Not sure what is to service an 24 valve Busso in the US but here they are reliable and will go distance. In fact there is a 330k km 147 GTA in my neighborhood. Original engine and gearbox.
Wife drove an 01 T&C for around 9 years, the 3.3L in it was fine although it leaked oil. It was all of the stuff connected to the engine that gave me trouble. IAC, water pump, alternator, some other sensor, injectors, AC compressor -all were replaced before 115k miles when I sold it.I kinda liked the 3.3 I believe was in my 2003 (Grand?) Caravan Sport SE. I think it may have been a sludger.
I did not have it long enough to know.
Okay how about Volkswagen VR6
You’re right, BUT the repairs I listed for the 3.8 are relatively cheap and easy to perform - even though they may sound a bit scary. Subaru on the other hand? Yeah, those engines will never be on anyone’s “best” list.That is like saying other than head gaskets and leaks and lots of engine work needing the removal of the engine Subarus are great cars.
Speaking of things connected to that engine...you forgot the transmission. Almost a guarantee for that thing to grenade between 75,000-125,000 miles. There are post secondary schools with thousands of those Chrysler transmissions sitting in their transmission classrooms because they all have been donated (and out of service due to failure).Wife drove an 01 T&C for around 9 years, the 3.3L in it was fine although it leaked oil. It was all of the stuff connected to the engine that gave me trouble. IAC, water pump, alternator, some other sensor, injectors, AC compressor -all were replaced before 115k miles when I sold it.
That 3.3 had no guts...but man was she smooth. Had to look down at the tach just to see if it was running sometimes.
Know a guy that could not blow up a slant six Dodge Dart -- literally put a brick on the gas pedal in park and walked away. Just would not die!!!Slant 6 of the Dodge Dart , Valiant (?) and Scamp . Took a beating .
It didn't fit the new Dakota, which is why they made the 3.9 V6...though making what was essentially a late-50s design meet emission standards couldn't be easy.I also thought of the old 225 slant 6. Those were bullet proof reliable engines, but only the last couple of years had hydraulic lifters that did not require being adjusted often. My 1976 Volare with solid lifters required adjusting the valves every 10 K miles. They were easy to do, but they were something that you had to keep on top of. You did have to keep a spare ballast resistor in the vehicle because you never knew when it would burn out, but you could swap that out in less than 10 minutes, and they rarely failed and usually only on start-up.
I once heard that Chrysler had to stop producing the 225 because it could not be made to meet the increased emissions requirements.
6V92TA.Detroit Diesel 6V-71.
I owned two of them and could never understand the fascination with that engine. Both of mine stunk. OTOH the 300 I-6 from Ford was the best 6 cylinder engine ever made imo. Sorry if I drifted OT talking inline 6's here.Slant 6 of the Dodge Dart , Valiant (?) and Scamp . Took a beating .
