Toyota longitudinal 1GRFE
or Honda J series pre VCM or VCM deleted
Typhoon as well....Those trucks are quite rare & they burnt up 700R4's frequently when pushed hard. But it did prove that the 4.3L responded just as well to forced induction as the 3.8L Buick.....Not that GM ever did anything with it.4.3 turbo syclone motor
Yes, I have been dreaming about swapping a twin-turbo LV3 into mine. 600 hp would be pretty easy.Typhoon as well....Those trucks are quite rare & they burnt up 700R4's frequently when pushed hard. But it did prove that the 4.3L responded just as well to forced induction as the 3.8L Buick.....Not that GM ever did anything with it.
Could you imagine a 4th Gen Camaro with a Turbocharged 4.3L?
Even though I'm not really a fan of the cars they make, I'd vote for Nissan's VQ series as the best V6 ever made. It's easily the engine with the most Ward's Top 10 engines of the year awards which is saying something. Honda's excellent J series would be the runner up in my books.
Had a 4.3L in a SWB 4WD GMC … with the electric fans … the whole front of engine was accessible …Typhoon as well....Those trucks are quite rare & they burnt up 700R4's frequently when pushed hard. But it did prove that the 4.3L responded just as well to forced induction as the 3.8L Buick.....Not that GM ever did anything with it.
A good friend of mine (going to preface this with "wrong tool for the job") tried to pull his boat out of a local lake on a very steep ramp with his Astro van that had the 4.3L. It would not pull it out, it just sat there and leaned against the converter once the weight took hold (this was a small cabin cruiser). My old '97 Explorer with the 4.0L OHV, but which had 4LO, hooked that up and out it came no problem.Had a 4.3L in a SWB 4WD GMC … with the electric fans … the whole front of engine was accessible …
77K trouble free miles …
Off-road you needed 4Lo … and it didn’t even tow a bay boat well … so back to V8’s …
HaHa … at least those StroVans were not FWD tire eaters … they were decent down southA good friend of mine (going to preface this with "wrong tool for the job") tried to pull his boat out of a local lake on a very steep ramp with his Astro van that had the 4.3L. It would not pull it out, it just sat there and leaned against the converter once the weight took hold (this was a small cabin cruiser). My old '97 Explorer with the 4.0L OHV, but which had 4LO, hooked that up and out it came no problem.
Not sure how that would have played out in a 2WD pick-up with highways gears, but I suspect the same way as it did with his van.
2JZ. Put 1200 horsepower through many other 6 bangers and tell me how the engine takes it.
Not a V6?2JZ. Put 1200 horsepower through many other 6 bangers and tell me how the engine takes it.
Ha trueNot a V6?![]()
Those 1200hp 2JZ’s only make power above ~5,000rpm.2JZ. Put 1200 horsepower through many other 6 bangers and tell me how the engine takes it.
am i wrong on this i would assume the vulcan wore reliable than the GM offerings. is that wrong?
Is that the same V6 that was in the mid 80s Thunderbird?3.0 Vulcan. Have seen multiple examples in Rangers go over 400k. As touched on earlier in this thread the cooling system is a weak point in the Taurus/Sable platform but the engine would usually still be going strong at 250k or so when the trans let go or body rust made them non repairable.
My high school friend had an 86 T-bird (ex fleet car, got it in 87) and that car was incredibly smooth and rock solid!! I always loved those cars.It was the 3.8L that was in the T-bird.
