That is like saying other than head gaskets and leaks and lots of engine work needing the removal of the engine Subarus are great cars.Toyota 3.5 2GR-FE
Excellent reliability, power and fuel economy.
GM 3.8
Aside from the intake failures from the EGR tube cracking them, leaking coolant inside. Or the coolant bypass tube...these were solid engines with reliability, power and decent fuel economy. A lot different than their little brother, the 3.4 V6 GM junk.
The EKG is a 3.7 L V6 version built in Detroit, Michigan. It displaces 3.7 L; 225.8 cu in (3,701 cc).[4] The bore and stroke is 3.66 in × 3.57 in (93.0 mm × 90.7 mm). It is a 90° V engine like the V8, with SOHC 2-valve heads. It utilizes a counter-rotating balance shaft mounted between the cylinder banks to deal with vibration problems of the 90-degree V6 design, as well as use a 30-degree split pin crankshaft to fire the cylinders every 120 degrees. Output is 210 hp (157 kW) at 5200 rpm with 235 lb⋅ft (319 N⋅m) of torque at 4000 rpm.[4] It has a cast iron engine block and aluminum SOHC cylinder heads. It uses Sequential fuel injection, has roller followers, and features fracture-split forged powder metal connecting rods and an assembled reinforced plastic intake manifold.
The scream above 5,000rpm is unbeatable.It has to be Alfa Romeo 3.0 or 3.2 24v. Who drove one would know.
Yeah sure, but I6 became such rarity that people think everything is V6.Those would be inline-six engines, not V6. I personally don't have any V6 engines I like besides maybe the Honda J series V6s, as I prefer I-6 engines.
Yeah … an in-line six is a great engine design … just tend to be a bit on the long side for some vehicles and have different impacts in manufacturing … Other thing is how much power gets made from boosted 4 bangers … so the I-6 sees pressure from that along with the V6 …Yeah sure, but I6 became such rarity that people think everything is V6.
I'm voting for GM Series II and later 3800's. Especially the Eaton M90 S/C equipped ones. I don't know that I've ever driven another V6 engine with quite the same combination of reliability (other than the well known LIM, coolant elbows), broad torque, power and fuel economy. Despite having a 90* bank angle, the inclusion of a balance shaft made it a very smooth running engine. Also sounded quite good with the right exhaust. Another thing that isn't always fully appreciated is packaging and simplicity.
Honorable mention goes to Honda J series, or Nissan's VQ-- those are a tossup for me. I lean toward the J-series as VQ engines are often difficult to work on.
Yeah I know that. Biggest issue in automotive sector is transverse position of an engine. But I6 are coming back a bit. Modular engines are big thing now, and 3, 4 and 6 cyl are basically same family. MB is back to I6, Mazda is going that way, FCA...Yeah … an in-line six is a great engine design … just tend to be a bit on the long side for some vehicles and have different impacts in manufacturing … Other thing is how much power gets made from boosted 4 bangers … so the I-6 sees pressure from that along with the V6 …
We see the same in industrial engines … Can’t picture an I-16 myself,
I had 146 1.6 boxer. Amazing vehicle in every aspect. Super reliable.I had 147 GTA for a spinn few times, how this engine sounds and perform in stock form is unbelievable, pure exotic. With Ragazzon full flow, Q2 diff it becomes great. It feels special. Very reliable also.
