Hi everyone, I have a (new) John Deere 35G/Hitachi, but that does not really matter because this should be a more general question.
What is the typical operating temperature for the hydraulic pump? and after operating for a while, how hot do the cylinders feel? And what is your ambient temperature?
For me, on a cool day (21C), the temperature is about 42C on the cylinders, and 44C on the tank return line (after the oil cooler). This temperature seems normal, however on a hot day (34C), the cylinder temperatures are like 68C, and the return line is about 75C, and the outside of the pump itself is a few degrees hotter. This seems way to hot, because the oil viscosity of vg46 oil is about 10mm2/s at 75C, thats below the minimum of 20mm2/s for my pump.
However, from what I read online, its normal for operating temperature to be 38C above ambient, but not sure how true this is...
The pump does not seem to have a pressure compensation, just has one unknown line going to the base of the pump thats connected to a solenoid valve from the pilot pressure, not sure what this does. I do notice the hydraulic movements gets slightly slower under load. What adjustments can I make to the pump?
If anyone has any information, please share your knowledge with me. The dealers/service does not have useful information regarding this.
Thanks
Wes
Thanks
Wes
