Not when your API oils exceed the IIIH test by 20x.![]()
If there's oils exceeding the test minimum by 20x, the minimum should be raised, a lot!
Dealer bulk oil is not Mobil 1 Extended Performance, Castrol EDGE Extended Performance, PUP or Valvoline Restore and Protect.
Does the winter rating play a role here when talking about thicker? I.e. would a hypothetical 10w-50 do the same in this application?
Thanks for the read! Very interesting info.
It reminded me to tell next time the guys that always run top tier fuel that their intake valves get dirty not because the low tier fuel burns dirtier than top tier, but because EGR gases pass trough (and there is certain amount of oil in them) them regardless of port or direct injection.
I'll mention that in the top tier fuel threads later this week.
German cars (mostly turbo) that run thick Euro oil get stuck piston rings and burn oil regardless of the better quality oil. What about that?
Not really, not unless that winter rating translates into gobs of vii and epic HTHS loss.Does the winter rating play a role here when talking about thicker? I.e. would a hypothetical 10w-50 do the same in this application?
My primary gripe is that the thin oil efficiency advantage doesn’t exist in the real world. The 1-2% disappears in a world of drive through and sit in your car idling to goof off on your phone.100% agree. Well said.
I feel as the premise of this thread points to an overwhelming contradiction/incompatibility of things....., requirements, lube, fuel, design, driving style etc. The sum of which is not good for the consumer, and by and large, counter productive to the "efficiency" goals.
Agreed. The 1-2% is not worth the headache. Juice not worth the squeeze. One factor that should have input is the cost of repair and replacement. Cost is an inefficiency. Folks have to use energy and produce work to make money to fix these dumb problems.....Ill bet that if that factor was input, the"fact" would be much harder to defendMy primary gripe is that the thin oil efficiency advantage doesn’t exist in the real world. The 1-2% disappears in a world of drive through and sit in your car idling to goof off on your phone.
So we’re doing a net harm to the environment and making cars less durable.
How does the oil break down / oxidation theory of thinner oils, line up with a general lack of cylinder wear observed?My primary gripe is that the thin oil efficiency advantage doesn’t exist in the real world. The 1-2% disappears in a world of drive through and sit in your car idling to goof off on your phone.
You can have good wear control despite oxidation.How does the oil break down / oxidation theory of thinner oils, line up with a general lack of cylinder wear observed?
The (many) engines that I installed new rings on, most had 80-90K miles - some over 100K, the cylinders still showed the factory cross hatch.
And many people here, have reported fixing their oil consumption by chemical means - no new parts were installed. No worn parts needed replacement.
How does oil break down occur with no real wear?
It's actually considered one of the most stringent oil tests - 305F oil temps for 90 hours.If there's oils exceeding the test minimum by 20x, the minimum should be raised, a lot!
My opinion:I'd be interested in the science behind sulphated ash vs long term engine wear. I.e. is the risk to emissions equipment really outweighed by the additional wear caused by low SAPS oils? if there is additional wear caused at all?
Indeed, they aren't necessarily the same thing until the oxidation has progressed pretty far. Eventually, those glazed rings WILL cause wear. But sometimes you just get crud stuck in there without it being severe enough to generate a ton of wear.You can have good wear control despite oxidation.
More followup questions:Indeed, they aren't necessarily the same thing until the oxidation has progressed pretty far. Eventually, those glazed rings WILL cause wear. But sometimes you just get crud stuck in there without it being severe enough to generate a ton of wear.
My own odyssey van is likely an example of that. The Valvoline Restore and Protect is almost certainly cleaning rings as much as its cleaned the overhead. However, the van has no evidence of any oil consumption or major wear that I can detect.
Why would TGMO specifically?Thanks for sharing. Oxidation is a big deal and should be carefully monitored via a used oil analysis.
If you're using a lower viscosity oil it's important to choose wisely. You want strong oxidation resistance, stout detergent levels and solvency.
VII quantity and type may play a role too. With so many people using dealer bulk 0w20's it should be no surprise that rings will eventually stick at some point. Especially TGMO.
But that doesn't change the minimum standard... that it's 20x better than, lolNot when your API oils exceed the IIIH test by 20x.![]()
Intake valves generally stay clean on port injected applications, regardless of EGR or PCV, because the fuel is bathing the back of the valve, keeping it clean. This is what DI lacks, which is why, when DI was implemented, we saw the emergence of wallnut blasting the intake valves, something we didn't have to do with port injected applications.Thanks for the read! Very interesting info.
I can't wait.I'll mention that in the top tier fuel threads later this week.
Some German cars (specific Audi engines for example) were victims of poor design decisions, just like certain Toyota engines, that resulted in ring sticking and oil consumption. While higher quality oils might delay the inevitable, these applications are predisposed to these issues, so unless you have a product that's able to clean faster than the deposits accumulate (and actually flow through the region, removing the existing contaminants, which, on some of these designs, they can't), you are going to succumb to them eventually.German cars (mostly turbo) that run thick Euro oil get stuck piston rings and burn oil regardless of the better quality oil. What about that?
I assume because it's VII city.Why would TGMO specifically?
In my case, a 2% improvement in fuel economy translates to $1.65/month. A little extra viscosity is cheap insurance.It's unfortunate that we guinea pig consumers are the ones who pay for these questionable improvements. Engineering isn't cheap.
One wonders if the end user recoups sufficient individual fuel savings to compensate - including ongoing maintenance and repair costs.
