My LT1 Corvette has a stroker engine and it was built with low tension oil rings, so I get allot of blow by,and i use a quart every 1000 miles. I think because of the low tension rings the oil gets black due to fuel contamination blowing by the oil rings. I may be wrong. But what oil would be good to handle the contamination. I plan on getting the oil analyzed as soon as my kit comes. But until then, what do you recommend.
BTW, my engine is a high compression, 11.1to1, 6500 rpm redline engine, with .018 ring gaps, and the engine does not have the traditional oil burn on start up which suggests cylinder heads valve guides are not leaking.
