Originally Posted By: tsduke
Originally Posted By: crw
I save up about 6 or 7 gallons, then take it to Checker, AZ, or WM. I just pour it back into the same containers that it came in.
I've never understood why someone would use another container. Normally when you're changing oil, you have a fresh batch of empty containers waiting to be refilled with the old oil, and rarely do I take out more oil than I put in.
What I'd like to do, is have an oil burning furnace for the garage, but the ROI on that would take a long while to justify.
I often have a quart or so still in my pan from lawn mowers or snowblower so it won't fit in a 5qt jug after a car change. Also easier to have a bigger container when my truck takes 6 qts and I only partially use one of my 5qt jugs.
Sure, no problem with that. That's what I do too. I'm talking about grabbing some inappropriate container when, if you change your own oil you *should* have the original jugs to use. I will also re-use the 5-quart jugs to avoid using individual quarts (now that I'm using Mobil 1 0w-40) but, if all I have is the individual quarts, that's what I use.
As the OP mentioned, people were bringing used oil in breakable containers...?
