My 4.0 Tacoma sounds different depending on time of day, temperature, astrological cycle, and whether or not another idler pulley is going out.I switched oil brands (both 5w30) in my 4.0L V6 Tacoma, and one made the engine sound a bit quieter at idle than the other.
How many miles are on it? Ever have the valves checked and adjusted?My 4.0 Tacoma sounds different depending on time of day, temperature, astrological cycle, and whether or not another idler pulley is going out.
It’s ironic that one of the most reliable engines actually sounds like it’s going to shake itself apart at any moment.
I’ve never noticed a difference in sound after an oil change to a different brand. It just goes tickTicktickticktixktixktixktixcttickticktick no matter what - and will likely continue ticking well past 300k miles regardless of what I put in it.
I concluded nothing.
'Loud' oil is the construct of the uninformed few OCD internet avatars that are looking for both an intangible problem and an unmeasurable solution to that problem.
Cheers!!!
My experience too. The Castrol EDGE Extended Performance I have in there now on the other hand, is very quiet.Mobil1 is known as loud. Stellar UOA though.
always go with the heaviest grade possible, luxury oil.
Sure didn’t mean anything to my DB meter …My experience too. The Castrol EDGE Extended Performance I have in there now on the other hand, is very quiet.
I don’t think it means anything, but it’s something to keep in mind if you are getting ready to unload the buggy.
Our 2010 Tacoma work truck where I work sounds the same. Also changes in volume level like you said. Mostly sounds like fuel injectors but also some valve train and piston slap. Very rough, noisy engine compared to my 4.8 GM. Both will last forever though.My 4.0 Tacoma sounds different depending on time of day, temperature, astrological cycle, and whether or not another idler pulley is going out.
