What do we lose with API SP oils and older engines?
Retiredville SC
Specifically in the VW/Audi speced 502.00/505.00 requirements. I know the SL, SM and SN oils were higher in some adds that may have been viewed as beneficial to the older engines, such as calcium, zinc, phos etc. I still haven't figured out what, if anything, we gain/lose with move to SP, other than the lower calcium for LSPI prone engines. I know if they meet approvals, then from that standpoint it's moot. Just wondered what it really means moving to SP for older stuff.
You can have a look into the Afton Book where individual tests are defined. I have learned that the requirements for oil quality, engine cleanliness, and engine protection are usually increasing. This way the backward compatibility from API SP to API SL is assured -API SP is better than API SL. Additionally, the recent research improves knowledge of tribofilm formation, robustness, etc. Therefore new oil formulations benefit from that additional knowledge.
We have 20+ year oil toyota where API SJ was prescribed. The car was filled-in with API SJ, API SL, API SM, API SN oils and is likely to get some API SP oil in the future.
Moly is mostly for friction reduction and much less anti-wear. Moreover, moly was found to compete with ZDDP therefore one cannot say that high moly is better than low moly or high zinc is better than low zinc. It is not that easy.
I like oils that have some moly, some boron and some demanding approval.
My safe bet for very good engine protection is oils with one of the MB 229 approvals. If you can find any oil that has valid MB229.5 approval you can be sure you have an excellent oil that is highly likely to meet or exceed the protection provided by the best oils that were available 15-20 years ago.
Compared to API SN, API SP requires better performance in the fuel economy and high temperature piston deposits tests. The valvetrain wear test was replaced with a different one. That's about it, besides the LSPI and GDI timing chain wear tests.
The GM Dexos 1 Gen 3 certification has a lot more requirements on top of API SP, notably much more stringent requirements for passing the sludge test, and a lower maximum NOACK (12.5% vs 15%). There are also additional tests for wear, fuel economy, high-temp piston deposits, that may be more stringent than the tests required for API SP. There's also a turbo deposit test that has no equivalent in the API standards.
MB 229 and VW 508/509 require even lower NOACK than Dexos (11%). MB 229 also requires a minimum TBN of 7.5 and higher minimum phosphorus than API SP. As far as I can tell, these euro standards don't require any unique engine tests, just some spec sheet requirements.
So while there's not much benefit to API SP over SN for older engines, I think that an oil with API SP and Dexos 1 Gen 3 does add a lot.
Phosphorous has been restricted on xW-30 and below grades since API SL. There is no limit on zinc.
Calcium is reduced (and magnesium increased) since API SN+, which was to help with LSPI
An API SP 0W-40, other than having a different detergent package (more magnesium, less calcium), will have the same level of phosphorous as it did when it was API SL.
Moly is synergistic with ZDDP, it improves both wear control and friction reduction. Of course the dose required will vary depending on other components and the type of moly being used.
Overkill: I am aware of that document. For this reason, I like oils that have at least some moly. On the other hand, I was wondering, why some manufacturers used high concentrations of moly, even if they used dimer, some concentrations were surprisingly high (e.g. 600+ppm).
I found some interesting answers in the paper below, sections "3.1. Friction analysis", "3.2. Tribofilm thickness" and "3.4. Wear analysis" were interesting (at least for me):
https://www.sciencedirect.com/science/article/pii/S0301679X2200010X
So are you suggesting that manufacturers have altered their approval requirements so that the oil can also gain an API license?
I think the obvious limitation of that study is that they used a fully formulated oil minus an FM and then dosed it with a specific moly compound. In my discussions with @High Performance Lubricants, there is an optimization process for each base oil blend and additive package that is then tested and further refined with a group of FM's in order to achieve the best results. This means a combo of moly trimer, dimer and even tungsten (and potentially titanium FM's as well).
Since you are familiar with the Infineum presentation, you know they contrasted the performance and characteristics of different moly types, but never blended dimer with trimer because the presentation was about the performance advantages of trimer over dimer.
I have made it a point of using SN rated 10w40 oil in my 1998 Volvo S70 N.A..Specifically I use Pennzoil 10w40 because of moderate Phosphorus levels..Phosphorus is known to damage catalytic converters and based on specs on oils that's I've researched I.e Mobil 1 synthetics, I find I am better off using a 2010 SN oil for a 1998 engine than a 2024 SP rated oil..
Yes if it gets there and in a fairly high amount. The one time I saw a car with a catalyst efficiency code due to the oil was one that consumed a quart in less than 500 miles. How much oil is your engine burning?
I would think that the SN rated oil would have more Phosphorus than the SP rated Oil. I always thought what damaged a Cat Converter was burning oil. When these Converters came out back in the day, the Phosphorus Numbers were much higher in the Oil's.
I do get caught up on the Phos Level and other things in Motor Oil, just use Mobil 1 ESP or 1 of the HPL Oil's.
The current phosphorous restriction on grades xW-30 and below started with API SM. It has not changed for SP.
Has anyone done a used oil analysis that shows a modern oil causing excessive wear particulates in a sample from an engine with no mechanical defect that would cause it? In other words, has an older engine died simply because of oil formulation over the years, or simply by its older design in general?
Currently my 1998 Volvo S70 uses about 1 quart every 3000 miles..all I've used since I've owned it is 10w40 weight...PQIA states that Pennzoil 10w40 has phosphorus in the 600 ppm range..hence the reason I prefer it for the Volvo...no issues at all with this oil...
