- Joined
- Jan 21, 2026
- Messages
- 35
For me:
Front pads: Ferodo Premier. The "premier" branding is just fancy marketing speak for Ferodo's OE replacement pads.
I experience "brake creep" when the pads are cold. Disappears as you get heat into the pads (ie after a few brake stops).
Unsure if it's due to not machining the old rotors, or whether the friction material rating is the cause (which is what I suspect).
For what it's worth, the images online state these pads are "FF" friction rated (which is what I wanted), but the pads I received were "GF".
Bar the minor brake creep issue, pads are otherwise fine. No brake squeal, low dust...perfectly fine for my A-B driving.
Rears: Bosch Quietcast.
Perfect thus far. Used on old and new rotors (long story). No squeal, no brake creep, little dust...happy so far.
