Ya know I did a '94 Caravan a couple years ago and while I'm sure there are even more difficult examples it was similar to your experience.The blower motor was bad in this 2015 Nissan Versa Note. This really makes you appreciate the blower motors that are placed under the glovebox.
I’ve replaced several blower motors in Nissan’s of this vintage down at the car lot. Seems to be a failure prone part,…at least in my experience.
The drivers floorboard with the steering shaft, throttle assembly, brake pedal assembly, and various other little parts removed and everything unplugged. View attachment 122237
The offending part, hiding way back up in the deepest part of the dash right against the firewall.
(Edit-The offending part had already been replaced, this is a photo of the aftermarket replacement I installed.)
View attachment 122238View attachment 122239
It’s not the only thing I worked on today, but I’m so impressed with their placement of these blower motors, I thought I should share. Thank you Nissan!
If you distort your body just right and cut a bunch of rubberized insulation from the firewall then pry some other stuff out of the way with one hand whilst shoehorning it in with the other hand it barely makes it
