Been tinkering with a new yard plow truck, 1990 Bronco II. I've already plowed snow with it and while it was a champ the brakes weren't great. In fact standing on the rock-hard pedal barely slowed it down. Previous owner was an absolute idiot so I eventually questioned everything. I knew one port was blocked on the master cylinder so it was front-brakes only, but then discovered he was running the fronts off the rear port. Switched that around and now it locks up the front axle, and does the most amazing burnouts in 2wd.
Other highlights of this
truck:
-- Paid $500
-- It wasn't running when I got it because it had a flat battery. Boosted it and it started right up. They changed the alternator (thanks!) but never charged the battery.
-- Wipers didn't work because of a bad ground. Ground wire was clamped in with the wiper motor mounting bolts and the rubber sound insulators. I found that dumb and just ran a self-tapper right to the firewall.
-- Rear leaf springs are held in with hopes and prayers. Now one's also held in with a period correct Ranger shackle, 1/10 the price of a Bronco II item. What's the difference? 1/2 inch of clearance, so I shimmed that thing out and called it good 'nuf.
-- Wasn't sure about the 4wd so I took the front hubs apart and welded everything together. It has this system where when you demand 4wd and the wheel spins, some plastic cams shove some stuff around in the hubs and they eventually click in and out. I don't have a lot of driveway nor patience for this.
-- There were acorns EVERYWHERE. In the glove box. Center console. Air filter box. HVAC squirrel cage fan and duct. Behind the heater core. This thing has the EASIEST in the world heater core to R&R. Put my gloves on and removed copious messes.
Photo of the day I bought it:
Photo of some mouse carnage:
