Took a look at my 2008 Mercury Grand Marquis that had a brake problem on my brother’s last trip back. He reported a brake dragging and the wheel being very hot to the touch. Also said it was down on fuel mileage so he figured it was a sticky caliper.
Took the wheel off the left side, where he said it was hot. Nothing unusual. I was able to move the caliper on the slide pins and I was also able to compress the piston when I took it off. In fact, it was no problem at all, unlike one that might stick and drag. Parking brake shoes were intact.
I put my new rotor on after retracting the parking brake shoes a couple of turns. I installed a new caliper since I had them, with an eye to reconditioning the original.
Right side? I found the issue. The parking brake shoes had failed and pieces of friction material had jammed up the mechanism. The axle bearing seal is weeping and enough gear oil got in to contaminate the assembly, causing the friction material to break apart. Job got more involved now.
Not having the replacement parts for that, I cleaned out the broken parts, cleaned out the assembly and reassembled the right side with my new caliper, rotor and pads. The leak is small, so it should be ok to wait until I get new parts in on order.
My fix for this is to replace both axle shafts, bearing and seals, differential cover, and parking brakes. I’m pricing out parts via RockAuto now. Seeing as the rear shocks are factory originals with 205k miles on them, I’m inclined to swap those out as well. They are very easy to access (unlike on older Panther platform cars) so I’ll likely do those too.
The leak is small and confined to the parking brake rotor hat so it should not affect my new pads (the old ones had a lot of material left and were unaffected but the rotor was coated inside). I drove the car to bed the pads and rotors (Bendix FleetMetlok pads and coated rotors) and it was perfect. But this repair is on my list.
