I gave him 2 different quotes....
*He supplies a unit & I install it.
*I sell him the good core & build it right.
Surprisingly he chose a full tilt build! A 2008 6L90E isn't a straight swap into a 2015 truck, The Valve Body & TEHCM are not compatible.
I was able to save the '15 Valve Body with a Sonnax Zip Kit. Had a low mileage 2017 6L80E TEHCM albeit with the incorrect OS so I had to program it with SPS2.
Borg Warner Frictions, Same as OE.
Updated Stator with a anti-rotational Rings (The '08 pump had a 1st design stator)
Leaked checked the 1234/25R Drum
Sonnax Billet 1234 Piston (OE is known to crack)
Had a 6L80E Durabond Bushing kit which is the same besides the Extension Housing/Output Bushing, No one local had it separate & didn't have any Durabond 6L90E kits either. Bought a kit from Transtar.....What a joke, I pressed in the bushing & couldn't even start the Slip Yoke in it!
Had to chuck the extension housing on the lathe & adjust out the runout, Used my small boring bar & bored out the bushing. Called the Transtar salesman & told him I shouldn't have to spend $90 on a bushing kit to need only one & it be a POS!!
