Slow day today. Had a 2005 Corolla towed in that Walmart done a flat repair on and they left the wheel loose. Customer drove it back to Walmart and their response was well it’s an old car so it’s going to make noise they wouldn’t even pull it back into the shop to check it. When it came in on the tow truck you could tell the wheel was sitting crooked. It’s a shame someone would let that go then blow it off with an excuse of it’s an old car. No it’s a car you just worked on and forgot something so you need to correct it. I made sure the customer didn’t pay anything I felt sorry for her. I understand mistakes happen or you forget something but you need to make it right.
Then done diagnose on a Tacoma a test drive told me the wheel bearing was bad. Got the work approved and waiting on parts customer requested OEM bearing so that’s what I am going to put in for them tomorrow morning. It’s the RF. 2017 Tacoma with 140,000. That’s work today.
At home I finished the valve cover gasket replacement on my 94 Camry. Then changed the spark plugs and tube seals too and replaced the front right signal bulb and front left headlight bulb. This weekend will be changing the oil and then changing the transmission fluid and filter and going to check the shift solenoids when I drop the pan. All the old timers at work said these were notorious for problems usually needing solenoids or transmissions.
Great tips. Yes reverse is the only thing it won’t do. Otherwise it’s smooth. When you put it in reverse it lunges foward very lightly and then just doesn’t do anything. I tried revving a little bit in reverse it does nothing at all.I saw you mentioned troubles with the A140E in your Camry.......Is Reverse the only thing missing?
If so.....Get it up to around 25-30MPH, Let off the throttle, Manually move the shifter down into Low/1st, You should have Engine Braking (Engine RPM will come up & the car will slow down)
If you have no engine braking....The car just coasts?....There's an issue with the First & Reverse Brake (B3) Clutch.
Don't waste time/money replacing Solenoids or doing any maintenance! The 2 Shift Solenoids only control forward shift timing!
Give the kids a case of beer......Got a little more done yesterday . Got the lines and wiring from the outdoor unit to the branch box, ran 1” conduit from the breaker panel to disconnect box w/ surge protection, and ran wiring/conduit to outdoor unit from disconnect box. 6/2 Romex from the breaker panel to outdoor unit, 16/2 for the communication wire and 14/2 for the branch box power supply. It’s very tough finding time while watching 2 kids that constantly want to kill each other…
hmm, probably good I'm not a parent.....
sharpWheel cleaning…
