Got 4 or 5 inches so far? elected to run the ATV & plow. No go. At first the plow would not work; brought it in. Suspected GND not making it to the relay block. Pulled a relay, tested it, fine. After putting it back in the works started to work. Ok, probably just corrosion. Took it outside, pushed snow for 5 or so minutes, and lost one relay, followed by the other. I'm starting to think the wiring has decided it's too cold to work--one relay still clicks but no operation. Either something is shrinking and losing contact, or the wiring has elected to quit (same thing?). Pushed the snow by hand easily enough.
Trying out my progressive lenses again. Still do not like, however over the last few days I've found it kinda annoying how much I wind up removing my glasses so as to see up close, then not see far away, etc. I think I found one trick: I put the glasses on the end of my nose. That's helping, although still nothing is quite in focus, ever, not quite as good as it used to be.
